07G35 Stutter In Power AND Stalls Randomly (Automatic)
Hello i recently bought a G35 2007, its been driving fine and all but today when i was driving i was noticing when leaving from a full stop the car goes to around 1.5k RPM then loses all RPM and the car full stops then resumes to drive now other then that 2 times when ive tried turning when in a parking lot my AUTOMATIC G35 completely stalls out and i have to restart the car this isnt that convenient becasue its a automatic once i notice i have to put it in part and start it up what if this happens at a red light n i cause a car to hit me or worse HAPPENS MID DRIVE!!!
PLEASE im new to the VQ G35/350Z scene and need help fixing this, now also i need a new O2 sensor ive ordered the part because no part store near me has them its been delayed due to covid19 for shipping twice now would a bad o2 sensor really cause the car to completely act like this? its completely stock
all 3 codes listed are the only one (I know the reader says 6 but it's just repeating the 3 codes)
P1148 - Closed loop function, basically saying it's in open loop because something is wrong.
P0031 - B1S1 O2 sensor, this is the primary air/fuel sensor. This code is saying the built-in heater is open/shorted, usually it's the sensor itself but occasionally it's the wiring or harness.
P0130 - B1S1 O2 sensor, this code is for the main part of the sensor, the part actually reading A/F ratio. It should fluctuate according to how much unburned fuel is in the exhaust but when they fail or get clogged up they just send a static reading. This code is the ECM saying it's stuck and sending a constant voltage back.
Open loop - When you first start the engine and the O2 sensors aren't up to temp they don't read correctly so the computer has a preset fuel table and doesn't use any correction from the O2 sensors.
Closed loop - After 30 seconds or so the sensors are all up to temp and will accurately measure air/fuel and the computer uses the sensors to trim fuel as needed. More power, more efficient, more betterer.
All 3 codes are related, if the O2 sensor doesn't work the ECM stays open loop. Sounds like you either have a bad sensor or melted some wires/harness. I would inspect it for wiring issues first and if everything looks good replace the sensor.
Only use name-brand sensors from a reputable company, Denso, Hitachi, Bosch, etc. Bank 1 Sensor 1 (upstream) O2 sensor.
Ricardo_Galeno
Feb 15, 2016 07:30 PM
NIROMU
Dec 5, 2013 07:25 PM
