Redline is actually 7900RPM?
Old Apr 18, 2020 | 09:06 PM
Serge Mullen's Avatar
I'll make this short and sweet.
While in manual shift mode today the car revved all the way out to 7900rpm before hitting the rev limiter. I tried to shift at reline (7500-7600rpm) in second, but I was late and it reached nearly 8Krpm before i could shift. Kind of cool and unexpected, looks like we actually have a 7900rpm redline in manual mode!
Old Apr 18, 2020 | 09:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Never trust a stock tachometer, the HR motor should have a 7500 redline, at least that's what it was in the 350Z. You will usually jump 100-200 higher when on the limiter in neutral.
Old Apr 18, 2020 | 09:42 PM
I'd agree except when in full auto mode it shifts right at 7600 on the tach. This clearly went higher.
Old Apr 19, 2020 | 01:49 PM
Hall Stevenson's Avatar
Connect an ODBII scanner and an app that shows more accurate RPM readings and see what it indicates.
Old Apr 19, 2020 | 02:25 PM
I might try that.
I'm the meantime can anyone else confirm? I can't be the only one.
I have an 07 G35x with I believe revision C ECM update.
Serge Mullen
Apr 18, 2020 08:47 PM
Parker6
Jan 25, 2010 12:19 PM
KDG35
Mar 6, 2007 10:17 AM
GrayG35
Nov 3, 2006 12:47 PM
Britishbloke
Feb 26, 2004 11:20 AM
