Installing aftermarket Subwoofer
Old Aug 11, 2020 | 04:55 PM
Hayden P's Avatar
G35x
Exclamation Installing aftermarket Subwoofer
I am installing a powered subwoofer in my 2008 G35x w/ the Bose audio and the only thing I am unsure about is how I should go about doing the Output Connections... Will it be a Low Level RCA connection or a High Level connection? Where will I make the connection?
Old Aug 12, 2020 | 02:54 AM
Scorpi0's Avatar
Yeah it will be a low level converter. The best line to tap would be the wires for the rear speakers on the input side of the Bose amp.
Old Aug 12, 2020 | 10:57 PM
909's Avatar
909
Your mom's boyfriend
Use RCA's broski. Assuming you use a phone or bluetooth adapter ...
IF you split the source, run one to the armrest aux in , and run another to the amp ....
You can DIRECTLY CONTROL the sub level independent of the stock Bose mids and highs.
Old Jun 28, 2021 | 06:16 PM
phillyphan's Avatar
Veteran: Navy
G35 Sport Fully Loaded
Do you happen to know which wires those are? I've been searching all over the place and see some people connected to the connector at the sub and others connecting at the amp. I would think you'd definitely want to tap into the wires at the amp, but can't figure out which wires to tap into. Installing the power and ground are a piece of cake. Determining which wires to tap into for the signal is what I'm trying to figure out. We're installing the Fosgate P300-10 powered subwoofer in a 2008 G35S Sedan.
Tennessee
Aug 30, 2011 07:15 PM
Ruta30
Mar 13, 2011 11:22 AM
black07g35x
Mar 28, 2010 01:45 PM
paranormal
Apr 20, 2005 11:33 PM
sarkastro
Apr 22, 2003 04:50 AM
