2007 g35x 7 speed swap
Nov 5, 2020 | 05:15 AM
Im curious if anyone else has thought of, attempted or completed a 7 speed swap to a v36 g35 at all. Any input will help
Reply 0
Nov 5, 2020 | 01:14 PM
I think that would be a lot of time/effort/money to make it work. Not to mention making it work the the transfer case/awd...
To my understanding, the 5AT is quite a bit more durable unit than the 7AT.
FWIW, the newer 7AT's that they use with the VR30 (2016+ Q50/Q60) are better than the older 7AT's from what I hear/read.
Reply 0
Nov 5, 2020 | 03:03 PM
I would stick with the RE5 5 speed if going for more HP. 7 speed isn't very good unless you are staying stock and wanting better MPG. There isn't a ECU that had a VQ35HR and 7 speed so you may think about just biting the bullet and swap to a full G37 drivetrain to make it a lot easier.
Reply 0
Mar 28, 2025 | 08:35 PM
Quote: I would stick with the RE5 5 speed if going for more HP. 7 speed isn't very good unless you are staying stock and wanting better MPG. There isn't a ECU that had a VQ35HR and 7 speed so you may think about just biting the bullet and swap to a full G37 drivetrain to make it a lot easier.
Actually you're wrong, the VQ35HR has been paired with the 7 speed on the F35, M35 etc... so in theory it is possible
Reply 0
Apr 6, 2025 | 08:14 PM
"5 years later..."
Reply 1
