Drivers door lock issue
Old Sep 28, 2021 | 03:40 AM
terrasmak's Avatar
G Sedan
Interesting situation, I can’t lock my drivers door !!
key fob locks all doors but drivers door was the first thing I noticed
next I learned that I couldn’t manually lock the door either from the inside
last ditch effort , I broke out the key and tried to lock it; didn’t work either
the actuator seems to be working in both direction but can’t get the door into the locked position.
tearing it all apart tomorrow, any suggestion
Old Sep 29, 2021 | 09:50 PM
909's Avatar
909
Your mom's boyfriend
Had it happen to me. Try something simple first like lubricating the moving parts.
Once you get your door locked you won't be able to unlock the door by the sound of your post
You have to remove the door panel to access the assembly.
Either a cable is kinked, in which case you straighten it ( my scenario) .
The cable can't release, so it stays in the open position. This is why you think it can't lock.
Or the end of the cable is not engaged , in which case you pop it back in.
Sounds like your actuator is working. Cables can't be purchased separately, as it's all part of the same assembly.
If you locked your door, and it won't open anymore, you can pop it open with a thick wire between the glass and the weatherstrip.
Unfortunately, our cars are super easy to break into once you understand the locking system.
Good luck.
Old Sep 30, 2021 | 06:27 PM
terrasmak's Avatar
G Sedan
It’s something internal of the actuator area, everything is enclosed in the area the striker engages. Grabbing one from the junkyard to take apart and play with. I doubt Nissan uses many different versions
Old Oct 2, 2021 | 02:58 PM
909's Avatar
909
If you pull the cables it should open and close.
What happens if you buy another one but yours still works.
Old Oct 25, 2021 | 06:33 PM
terrasmak's Avatar
G Sedan
everything works but I can’t lock the door. Can’t lock it with the switch, with the fob, using the key in the door or even by pulling it apart and pulling the cable
Old Oct 25, 2021 | 08:42 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If it won't work by pulling the cables it sounds like a broken lock mechanism.
Old Oct 26, 2021 | 08:29 AM
909's Avatar
909
There are 2 levers on the lock mechanism.
Try to move them by hand.
Also make sure you strike plate (hook) is aligned on your door pillar.
Rattpack boi
Feb 27, 2014 03:23 PM
SMOOTHYG35
Nov 22, 2012 11:43 PM
saltyload
Aug 11, 2012 05:22 PM
stoofpilot
Jul 6, 2010 03:41 PM
ninog35
Canada
Aug 17, 2007 02:29 AM
