Cars been sitting for 2.5 years - need advice
Old Nov 3, 2021 | 08:08 PM
Tjk20's Avatar
G35 sedan
Hi,
Im going to be buying a 07 g35 sedan soon from a friend but have a few questions. The car has been sitting in their driveway for about 2.5 years when they lost the key. It has not been started since. I am wondering what/if there are any concerns with this. It was well cared for in the time they drove it but it has been sitting for a long time. I plan to get the key replaced and check all fluids and change them asap. Other than that, are there really any concerns I need to be worried about buying this? Thanks
Old Nov 3, 2021 | 08:13 PM
Tjk20's Avatar
G35 sedan
Also I should mention the car only has 80k miles
Old Nov 3, 2021 | 10:26 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Not really, expect random rubber bushings to fail. Check for water damage and clogged runoff drains. Check for critters living in the vehicle.
Old Nov 3, 2021 | 10:38 PM
Scorpi0's Avatar
I would just changed the oil and the battery. Maybe the tires if they have gone flat and are cracked. Then start driving it and see if any new problems arise.
Old Nov 3, 2021 | 11:04 PM
Tjk20's Avatar
G35 sedan
Would you bother draining the gas or just see how it runs with the old stuff?
Old Nov 3, 2021 | 11:29 PM
Scorpi0's Avatar
2 years of gas here in LA would probably be fine to use. I dunno how the weather is in your area though.
Just try it and see what happens.
Old Nov 4, 2021 | 08:42 AM
909's Avatar
909
Your mom's boyfriend
Ethanol gas attracts water, again depending where you live. This can't be good for your fuel injection system. Ethanol free gas won't have this problem.
If you're really worried, you can drain the gas, or add fuel stabilizer or just add ethanol free gas and run it through the system. Old gas isn't very flammable. It's better than doing nothing.
Old Nov 4, 2021 | 01:37 PM
Scorpi0's Avatar
I love Project Farm!!!
Old Nov 4, 2021 | 09:14 PM
cleric670's Avatar
BANNED!!!
Depending on how empty the tank is I would just fill it up with 5 gallons of premium and see if it starts.
You could just siphon it out since the tank is easily accessible.
2K6G35c
Texas
May 29, 2012 05:22 PM
SinG35c
Apr 21, 2005 07:03 PM
