ATF, Differential, Transfer case, what??
Old Mar 2, 2022 | 11:09 PM
mpmiller37's Avatar
G35x
I have a 2007 G35x. I've done atf changes on other cars, but AWD is new for me. I want to change the transmission fluids. So I understand how and where to change the ATF, which is basically drained from a pan plug and filled under the hood using Nissan Matic-S.
I believe there is a rear differential, and in the front, a front differential or is this called the Transfer case, I'm not really sure.
My manual lists these fluids:
- ATF: Nissan Matic J (I understand that Matic S is the replacement)
- Differential gear oil: Super GL-5 80W-90 or API GL-580W-90 // is this for rear only?
- Transfer Fluid: Nissan Matic D ATF
So does the car have what's called a rear differential using the gear oil listed above? What is in the front of the car, there isn't a front differential AND a transfer case, right? Just need some clarification on what fluids go where on this vehicle.
Much appreciated !!
Old Mar 3, 2022 | 12:07 AM
mpmiller37's Avatar
G35x
I found a thread that answered these questions, so sorry for the redundant post:
https://g35driver.com/forums/v36-diy...d-drain-2.html
Old Mar 4, 2022 | 07:46 PM
Joenavy85's Avatar
G35x Base
That thread is the one I used, straight forward steps, no issues. Just be sure to loosen the fill plugs before pulling the drain plugs, can't emphasize it enough.
davidalindsey
Drivetrain
May 7, 2013 06:49 PM
eddystone
V36 Engine, Exhaust, Drivetrain & FI
Oct 28, 2011 09:04 PM
TurTLe*
Drivetrain
24
May 21, 2010 06:52 PM
JER
Drivetrain
41
Oct 11, 2009 11:57 AM
fast04G
Drivetrain
Sep 15, 2007 11:24 PM
