Water Pump Replacement Mechanic Price Gut Check
Old Jan 6, 2023 | 10:00 PM
juncho's Avatar
2007 G35 Sedan
I have a 2007 G35 Sedan (135k miles) and leaking coolant... I just found out from a local mechanic that the water pump needs to be replaced. Also, the drive belt squeaks a bit at cold start-up so my mechanic recommended that I replace this too.
I was quoted $1185 for both the water pump and the drive belt replacement (8 hrs of labor ($960) + parts/tax ($225)).
Does this seem like a fair price?
I'm not interested in addressing this myself as I just frankly don't have the time, unfortunately. Also, I'm located in Southern California... specifically, the South Bay area and would appreciate any recommendations for local repair shops.
Old Jan 7, 2023 | 05:03 PM
coffeysm's Avatar
I wouldn't say that is too unreasonable. On the older models there were two access panels you could open to get to the water pump and tensioner. On the later models you have to take the whole front timing cover off.
Old Jan 7, 2023 | 11:30 PM
Urbanengineer's Avatar
It’s a rough job unfortuantely. If you are going to be in that far, may as well replace gallery gaskets / timing guides. Good luck!
Old Jan 8, 2023 | 07:09 PM
99zx2turd's Avatar
how do you know it's the w pump? i've replaced mine a few months back and the leak was coming from behind the a/c compressor. the job kinda sucks (it's not hard, just meticulous), but can be done if you've been wrenching on cars before. mine had 240k+, so it was a good opportunity to replace the main chain, tensioner, sprocket, and guides as well. honestly, 8 hours @120/hr for him to knock this out is not that bad at all.
Old Jan 8, 2023 | 07:46 PM
coffeysm's Avatar
I'd take Urban's advice too about replacing those gaskets they are made of paper and fail. I don't have an HR motor, but that is one reason why I would not buy a G from that era if I did not know those gaskets were replaced.
Old Jan 8, 2023 | 08:49 PM
juncho's Avatar
2007 G35 Sedan
My local mechanic diagnosed that the coolant leak is from the water pump. Per the recommendations here, I'll look to replace the guides as well.
Thanks everyone for the perspective. I've been calling around other local shops in my area, and was able to get estimates that are ~$200 cheaper. Based on the intel gathered so far, seems like $950-1175 for the water pump and drive belt replacement is reasonable.
Old Jan 8, 2023 | 08:54 PM
99zx2turd's Avatar
i'm really struggling with the w pump at that low of a mileage, honestly. it could be coming from the thermostat housing/pipe in that same area. at least jack it up and see where it's leaking from yourself before you commit to this repair.
Old Jan 8, 2023 | 09:10 PM
juncho's Avatar
2007 G35 Sedan
That's a great point and will do. Thanks so much for the advice.
Old Jan 8, 2023 | 09:17 PM
99zx2turd's Avatar
for sure. how bad is it leaking? when my pump gave way, it was like a niagara waterfall, you get the idea lol
Old Jan 8, 2023 | 09:25 PM
juncho's Avatar
2007 G35 Sedan
There has been no visible drips on the ground. Over the last few months, I've noticed that the coolant reservoir gets fairly dry every 3-4 weeks plus burning coolant smell. Then about a month ago, it's dry every 2 weeks. Thus, I figured my leak is getting worse.
The water pump leak diagnosis was from a local mechanic this past Friday. Looks like it'd be wise to get a second opinion.
Old Jan 8, 2023 | 09:28 PM
99zx2turd's Avatar
for sure. if it's the WP, you will see it on the ground since it's seeping out the weep hole. like i said, i'm very skeptical at this low of a mileage.
Old Feb 19, 2025 | 06:06 AM
00Baby's Avatar
Infiniti G35
Tbh yes I just got quoted 1480 for this job & im pretty upset for my 07’ G35
I'm not interested in addressing this myself as I just frankly don't have the time, unfortunately. Also, I'm located in Southern California... specifically, the South Bay area and would appreciate any recommendations for local repair shops.[/QUOT
Old Feb 19, 2025 | 09:50 AM
99zx2turd's Avatar
honestly, not a terrible price. all the accessories and the timing cover have to come off. does the price include new pump and chains? if you want the car to last a bit more get new chains, tensioners, guides and galley gaskets while you're in there.
Old Feb 24, 2025 | 08:19 PM
MaLPoPieS's Avatar
Jaguar XFR-S
That price is actually a very good one, assuming the parts are included (water pump, gasket(s), new oil and filter) make sure to get OEM parts and replace the chain guides. Otherwise, you might as well use that 1,500 as a deposit on a newer car..
Turbopseidon
Sep 20, 2021 03:21 AM
219g35
Jun 29, 2021 08:57 PM
816connie
Jan 25, 2020 06:36 PM
jangpk
Nov 22, 2017 08:11 PM
RedBaronK
Nov 9, 2015 11:06 PM
