Need some advice
Old Aug 6, 2023 | 12:51 PM
Jackson5g35's Avatar
G35s
Need some advice
My 2007 G35s Sedan was in need of front lower ball joints, my car has 230,000 miles on it. Because of its age and miles, I decided to just change out the whole lower control arm. I found a set on rock auto and now I am regretting it.
https://www.rockauto.com/en/moreinfo...pt=10401&jsn=2
I installed them Friday night and had it aligned and with new tires. One look at the car after it came out I could see the camber is way off, and the spec sheet confirmed, see below. Where should I go from here? Should I return the control arms? If so, what is my best bet to get ball joints and bushings replaced? Should I get a set of adjustable upper control arms? If so will they have enough adjustment to compensate for being off this much?
Old Aug 6, 2023 | 05:14 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I'm pretty sure they sent you the wrong upper control arms, you probably ended up with the ones for a 2007 coupe, not the sedan ones. Look up the same part number for a 2008 sedan, they should both use the exact same parts and the part numbers should match.
Old Aug 11, 2023 | 01:46 PM
G35s
You were right man, thanks for the insight.
robbydiesel9
Aug 18, 2018 11:25 PM
Albanian122
Aug 27, 2015 11:02 PM
gfunkjuanito
Jan 19, 2015 02:37 PM
NjMatteSedan
Dec 27, 2011 10:34 AM
TonyF
Dec 19, 2008 09:10 AM
