Tip to remove drivers side front inner axle on an AWD X?
Old Aug 8, 2023 | 10:07 PM
Maine35X's Avatar
G35X
Hello from Maine,
I'm beginning the project to replace the front differential and am at the stage of removing both of the front axles. The one-piece Passenger side axle popped out without any issue.
The 2-piece driver's side axle is being stubborn. Does it seat into the splined differential the same way as the pass side? With a circlip, that just needs to be popped using a pry method? I'm attempting to pull out the entire axle and still have the the two inner/outer 'halves' attached.
I'm using a Haynes manual that does not give instruction on removing the inner front axle...
Thanks for any advice.
Tom
Old Aug 9, 2023 | 10:02 AM
G2B35AGN's Avatar
You can download the Factory Service Manual from nicoclub.com. It may provide more detail to help you over the hump.
Old Aug 9, 2023 | 04:21 PM
Maine35X's Avatar
G35X
Thanks for the reply G2B,
I went to that site and realized that the 'net is loaded with false and phishing sites for product manuals - with questionable pop-ups appearing. It looks like I have to leave the site to download one. Is there a trusted area on that site to click on?
p.s. - I have a '76 Datsun Z and didn't know this site existed - thanks it might be helpful as all I have is a Chilton manual for that too.
<EDIT> I found the drill-down sections of the 2007 sedan manual. Very helpful indeed! Cheers and Beers!
Old Aug 11, 2023 | 10:45 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Get the FSM from Nicoclub, click the blue bars in the middle to open up your exhaust vehicle. They have full FSM for nearly every Nissan and Infiniti car, no need to register an account or anything.
As for the CV axle, yes it's just a circlip kind that you can pop out with a little prybar and a mallet.
Old Aug 11, 2023 | 11:20 AM
Maine35X's Avatar
G35X
Much appreciated Cleric670.
Sounds like I need to pry a little harder on it.
I've broken some things over the years by thinking that I just needed to twist, yank, hammer-smack, edge-pry, or torch heat to the point of regretting it. We've all been there though, huh?
Tom
eazdaskeez
Jun 9, 2020 06:25 PM
eazdaskeez
Jul 3, 2019 11:28 PM
Machine Head
Drivetrain
65
Dec 15, 2018 10:31 AM
botlfed98
V36 Engine, Exhaust, Drivetrain & FI
Apr 15, 2014 03:26 PM
