Vds and slip light on after rear subframe swap
I just finishing swapping my rear subframe and my vds and slip light come on after a mile.
07 g35s
manual
mods: welded diff,exhaust,coil overs
ive check my brake fluid and it’s fine
Shouldn’t be my brakes cause it never came on before I swap the subframe
i have 3 hypotheses
hypotheses:1
my alignment is off. My car doesn’t steer straight and I didn’t mess with anything upfront. So could my camber or toe be so far off causing my car not to go straight and making the wheel speed sensor unhappy causing the light
hypotheses:2
since mine is a S and came with the vlsd, the axles different from the open diff axles. I ended up just putting one open diff axles and using nut and bolt to hold it in. Could there be a weird thing going on since the axles are different on how they bolt up to the diff hub?
hypotheses:3
my wheel speed sensor are bad and they just need to be replaced and car need a new alignment.
07 g35s
manual
i have 3 hypotheses
hypotheses:1
hypotheses:2
hypotheses:3
08 G35 Journey
I have the same issue. The Slip and vdc light comes on before 1 mile. I think it turns on at about 30 MPH.
My alignment and tires are fine. Brakes and Brake fluid are fine. My car drives perfectly straight. Take my hands off the wheel and it won’t drift either way.
i can’t figure this out either
Matchstickman60
V36 Brakes, Suspension, Wheels & Tires
12
Jul 29, 2011 02:26 AM
