'08 G35x Driver Seat Forward/Back Failure
Old Nov 19, 2023 | 05:11 PM
SPB's Avatar
SPB
Infiniti G35x
2008 G35x recently purchased w/168,000 miles
Driver seat w/ memory. The forward and back function is not working. It worked intermittently upon purchase a couple months ago, but has now stopped functioning altogether. All other functions work well (recline, front edge lift, lumbar inflation).
-I identified the correct motor and removed it from under the seat expecting it to be bad. However, I tested it with direct 12v current from the battery and it operated well...including rotating both directions as I swapped contacts. I then reconnected the motor to the harness under the seat and no function...so somehow no current getting to the harness.
-I then suspected the switch, however I am hearing a definite "click" from under the seat each time I slide the switch (both forward and back). This "click" sounds to be coming from the white rectangular electrical box mounted under the seat. I believe that is the memory module? (The same "click" is present for the other properly working functions when activated.) The "click" sounds much like a relay being activated, which leads me to believe that current is indeed getting through the switch...which leads me to believe the switch is not bad. But I could be wrong. Suggestions on testing the switch?
-Assuming I am correct that both the switch and motor are not bad, what else could it be? I think the only other component in the chain is the white box. Thoughts?
Much thanks from a G35 newbie!
7milesout
Jun 10, 2023 06:28 PM
04vq35sdn
Interior
Apr 3, 2022 08:29 AM
MilesToInfiniti
Jul 26, 2019 11:28 PM
MarkhamX
Interior
Aug 23, 2014 05:00 AM
JRandallC
Feb 23, 2014 06:15 PM
