G35 Sedan V36 2007- 08 6m/t
Old Feb 28, 2024 | 03:56 AM
VQ35_KP's Avatar
infiniti g35 s sedan 6m/t
hi, my name is kp. I have a 2008 infiniti g35s sedan 6m/t I have fixed all my issues but I'm getting one error code which is P0462. I have changed my fuel pump already. I have also changed my throttle body's, Crankshaft position sensors, Camshaft position sensor, spark plug and coils. I have also check my fuse box near the battery and everything looks solid and fixed. Now I'm on a dead zone where it cranks healthy and doesn't want to start..... Could anyone help me out and try to figure out what the issue could be???
Old Feb 28, 2024 | 12:22 PM
G2B35AGN's Avatar
Funny. I'm having this code worked on right now. I'll post up once I hear the result.... On a tight schedule cause I need the car tomorrow, so not sure if they will be able to finalize this one today or not. Other work being done....
Old Feb 28, 2024 | 01:04 PM
VQ35_KP's Avatar
Please let me know asap because I wanna see if its a possibility to fix the issue ive had the car only a year and it hasn't started since ending of last summer???
Old Feb 28, 2024 | 05:14 PM
G2B35AGN's Avatar
Sad news, they were not able to work on the diagnosis for this problem today because they ran out of time. There are multiple issues that can cause that code, so they have to work through the FSM troubleshooting steps to isolate it. Sorry. I'm going to try to get it back to them soon, but you may have to chase this on your own.
Have you verified that there is fuel in the tank? If the gauge is not accurate for whatever reason, it could be an issue. Are you getting gas to the injectors?
Old Feb 29, 2024 | 06:08 AM
VQ35_KP's Avatar
The gas gauge isn't accurate it has almost full tank and im getting the gauge reading at quarter tank, but the car has gas and the injectors are getting fuel. im getting spark as well. I've been on this issue for awhile now and still getting dead ends
Old Mar 5, 2024 | 09:29 PM
Urbanengineer's Avatar
Could be the gauge cluster solder too.
bobby davis
Sep 17, 2025 10:55 AM
Jason Murrish
May 13, 2024 09:28 AM
Vq_Ghost
Jul 28, 2023 12:12 PM
VWownerwith1.8
Jul 22, 2022 11:01 AM
MiamiStancedG35
Feb 14, 2017 12:26 AM
