Identifying unknown connectors in fuse compartment
Old Sep 10, 2024 | 11:59 AM
Sparky14's Avatar
G35 Sedan AT RWD
Unknown male connectors attached to wiring in fuse compartment
Was pulling fuses while looking for a parasitic drain yesterday and dropped a fuse behind the trim. When I pulled the trim off I found these two connectors tucked in around the bottom of the fuse box. Could anyone tell me what these are for?
Also I found a 3A(!!!) drain on my battery that persisted regardless of how many fuses I pulled. I am assuming this is some issue with the alternator diode and I’m probably going to be replacing it ASAP.
New to the forum and haven’t had to wrench on my 07 Sedan ever. Now that it’s at 156,XXX miles things are starting to wear out and I expect I’ll be crawling this forum a lot more.
thanks!
Zmlony667
Oct 20, 2022 10:33 PM
7milesout
Aug 9, 2021 01:31 PM
kyazh
Lighting
86
Aug 6, 2015 10:58 AM
waijai
Nov 4, 2005 08:35 PM
briphi
Oct 6, 2005 02:32 AM
