G37 Coupe V36 2008+ Discussion about the G37 Coupe
G37 Wheel Specs
Old Aug 19, 2007 | 12:27 AM
Garnet Canuck's Avatar
Traveling Administrator
G37 Wheel Specs
For those that are interested, and was taken from the service manual.
Front: 19 X 8-1/2J Aluminum/43 mm
Rear: 19 X 9J Aluminum/45 mm
CrazyRuskie's Avatar
Sound like perfect Sedan fitment.... hmmm.....
Old Aug 19, 2007 | 09:49 AM
Chico's Avatar
interesting...those are real conservative specs for the coupe. Even the sedan can go more agressive. thanks for the info.
Old Aug 19, 2007 | 11:36 AM
IP37's Avatar
so, for the wheels newbies (like me) what does this mean to me if I want to put 20s on it?
Old Aug 19, 2007 | 12:07 PM
RBull's Avatar
Rated M
Looking at the car Chico the offsets seem more aggressive than the previous generation however. Maybe this is because of the track width increasing.
Old Aug 19, 2007 | 02:58 PM
Not a whole lot. Just make sure you get the right offsets with your sizes.
Old Aug 19, 2007 | 05:09 PM
bruddahmanmatt's Avatar
I want weight specs. I'm gonna go ahead and guess they're at least a few lbs. heavier than the forged Rays on the 05s-07s seeing as these new 19s are cast.
Old Aug 19, 2007 | 08:12 PM
JZ39's Avatar
Is the high offset going to limit how much of a dish can be had on the wheels?
Old Aug 19, 2007 | 08:21 PM
jdm_inspire's Avatar
^ High offsets (famous on Hondas) may limit the 'deep dish' potential on the current G. The 14" rotors in the sport model also may limit how much deep dish can be attained. We'll see what JDM manufacturers (ie Rays Engineering, Work, etc) will come out with to fit on the "Skyline" to see how far they can go. Maybe the vendors that advertise on this board can help us ... ????
Old Aug 20, 2007 | 12:57 PM
shaneotool's Avatar
When you look at the coupe in person, the stock 19's are pretty tucked. I would guess the same aftermarket wheels that could be used in the previous gen could be used on the G37. At least in the rear - the fronts would need a high-type wheel to clear the breaks.
Old Aug 20, 2007 | 02:27 PM
Skaterbasist's Avatar
Retired SuperMod
Atleast they wen't with 9.0 in the rear. IMO, my stock 19's for my 06 Coupe would be a better looking wheel if it were 8.5 front, 9.5 rear.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
itschuckster
Jul 25, 2015 08:07 AM
Soumilg
Jul 18, 2015 12:33 PM
