General Media Share Find and share Infiniti-related videos! Just took some pics for fun? Looking for general pics and vids? Try it out. Please post specific media (Mods, etc.) in its specific category in the Tech Area.
Digital Deviant Progress Thread
Old Jul 11, 2015 | 11:51 AM
  #211
DigitalDeviant's Avatar
Originally Posted by .cakestar
i feel like im just chucking wads of cash at my car. for the smallest details that 99.99 people wont even tell is modified unless they had the car themselves
So true. I feel your pain bro.
Old Aug 7, 2015 | 06:15 PM
  #212
Ready4aG's Avatar
Wow... Great build man I cant wait to see what the final out come of your car will look like.
Old Aug 16, 2015 | 11:24 AM
  #213
So my 06 projectors were really cloudy and beyond repair as the damage was inside especially with the stress cracks. So, anyone looking for replacement lenses and can find these cheap like i did. Do it, then just clear coat them.
Before
So, I bought a set of these ebay lights for 200 bucks new.
Then took them apart
Removed the bezel
Installed the 06 bezel and done
Old Aug 16, 2015 | 02:49 PM
  #214
saywat?'s Avatar
Nice so it fit perfectly? Bc its been asked many times if the lens were swappable and the answer was no. U could probably sell the clear strip for $20 lol
Old Aug 16, 2015 | 05:48 PM
  #215
Two tabs are off and the top corner has a small gap. But the screws work and it all sealed just fine
Old Aug 16, 2015 | 05:55 PM
  #216
rsingerG35's Avatar
Same thing is happening to my passenger side 06 projector and the inside is also clouding. Thought I was the only one.
Old Aug 16, 2015 | 07:44 PM
  #217
saywat?'s Avatar
So u only sswapped the lens right?
Old Aug 16, 2015 | 08:03 PM
  #218
Yep. The bezels swap right out and it's pretty simple. That's why I posted this because everyone talks about it but I've never seen it verified.
Old Aug 16, 2015 | 08:07 PM
  #219
saywat?'s Avatar
It's been awhile since I did my lights , wat are u referring to when u say tabs and bezel?
Old Aug 16, 2015 | 08:36 PM
  #220
I just checked again and all the tabs actually line up, I was looking at the wrong thing.
Anyway, see the 3 tabs / holes in the plastic?
Here is the gap at the top corner
And how they look now
Again, all the screws went in the lenses just fine and they are sealed.
Old Aug 19, 2015 | 10:18 AM
  #221
Time to send her off
Old Sep 11, 2015 | 01:51 PM
  #222
I've been busy. So this is the teardown of the new motor before being sent off to the machine shop, getting the bay painted and some carbon work that I am doing. Just waiting for the polished parts to show up from Baid and then i can start getting the motor put together, since it only took them 5 days to do the machine work.
Old Sep 11, 2015 | 03:27 PM
  #223
Mr. Brooks's Avatar
What motor work was done
Old Sep 11, 2015 | 04:01 PM
  #224
Engine:
Painted Bay
Painted Core support
Rebuilt Revup Engine:
Weisco Pistons 8.5:1
Eagle Connecting Rods
ARP L19 Head & Main Studs
Block inspected and cleaned
Block redecked
Block modified for better cooling with HR Headgaskets
Block Bored and Honed using a Torque Plate
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
New Moly coated Race Spec main bearings installed
New Moly coated Race Spec rod bearings installed
Block assembled
Cometic HR Head Gaskets
Heads inspected and cleaned
Heads redecked
Ported exhaust and intake runners
JWT S7 Cams
JWT Heavy Duty Valve Springs
5 angle radius cut valve job
Viton Valve Stem Seals
Ferrea Valve Train Kit
Valve Stem Heights set
Cold Clearance set for cams
Heads assembled
Cosworth High Performance Oil Pump
Mishimoto Low Temp Thermostat
Passenger and Drivers Side Wire Tuck
gredyy TT kit 18g - Turbo's rebuilt
APS intercooler
SxExCx Bolt / Nut kit - Red, Black and Chrome
Baid Polished Plenum
Baid Polished Throttle Body
Baid Polished Cam Covers
Baid Polished VTCS
Baid Polished coolant pipes
Baid Polished front timing cover
Baid Polished rear timing cover
Baid Polished 5/16 spacer
Baid Polished mrev2
Baid polished lower collector
Baid Polished Oil return
Baid Polished Coil pack covers
Z1 Stainless Steel Clutch Line
JDM Battery/Brake cover
RareJDM Polished Aluminium JDM Engine Wire Cover
Z1 Idler Pulley Elimination Kit + New belts
Import Parts Pro PCV valve AN Fitting (-8AN)
Z1 Master Hose Set (Black)
Mishimoto Radiator
Mishimoto Fan shroud
CDP Poly Motor Mounts
Z1 Poly Trans mounts
Z1 Poly motor mounts
Mishimoto Oil Sandwich Plate with 3 1/8 NPT threads
Pianted Valve Covers
Old Sep 11, 2015 | 11:52 PM
  #225
Mr. Brooks's Avatar
WOW, you're not playing around. One day I'll be in your shoes (especially if I get this new job) lol. I guess you're aiming for 600whp or more with a list like that, you can't go wrong. I remember, years ago. Probably 10 or more years earlier, their was a guy (I think he was a pilot), he had a G coupe with the same kind of work you're doing. If memory serves me correctly (and it does) it was making 700 plus horse at the wheels. The only thing that made it stand out was his wheel and tire setup. He had 20's but, everything was done right. Nothing flashy but, if you tried him. You were in for a huge surprise.
You have already rated this thread Rating: Thread Rating: 3 votes, 4.67 average.
