Idle Problem
Old Apr 11, 2007 | 07:12 AM
mrimage's Avatar
Idle Problem
anyone have a idle problem with there car like, when you warm up your car and shut it off then turn it on the idle drop to 500rpm and go back up. i take it to the nissan dealer cause my friend work there and he try to relearn the idle but the car won't take it. any advise from some one?
Old Apr 11, 2007 | 08:24 AM
Rphillips6487's Avatar
Several members have come across this issue, including myself. I just noticed this after taking my car out of storage.
do you have any mods, and if so, which ones?
Old Apr 11, 2007 | 08:32 AM
srmfball's Avatar
What is it supposed to idle at?
Old Apr 11, 2007 | 08:39 AM
commonly it should idle around 1,000 rpms
Old Apr 11, 2007 | 09:22 AM
DocJohn's Avatar
Idle speed is listed in the service manual as 600 to 700 RPM in Park or Neutral with all accessories off (lights, A/C, etc.).
Old Apr 11, 2007 | 09:35 AM
izmir41500's Avatar
G35driver Addict
try the resets at the end of the motordyne install manual.
Old Apr 11, 2007 | 10:20 AM
mrimage's Avatar
the current mod i have is AAM plenum spacer, JWT Popcharger and a exhaust system, also the other daymy check engine light came on and read back 1 and 2 running too lean.
Old Apr 11, 2007 | 10:22 AM
RebelinRI's Avatar
Or disconnect the battery when you go home at night. Then in the morning connect the battery again and maybe that will work for you. That reset thing never worked on my car. But it was probably me.
Old Jun 11, 2008 | 12:04 AM
soulamour's Avatar
i replaced my plugs and cleaned out my throttlebody, im having issues with my G35 idling just under 1000 rpm's any suggestions?
Old Jun 11, 2008 | 12:06 AM
soulamour's Avatar
when i punch my gas, to a higher rpm from idleing, as the rpms come down back to 1000, it then jumps up to 1500 and then settles back to 1000, any suggestions?
Old Jan 15, 2009 | 03:50 PM
Tollboothwilley's Avatar
same here
did you try the 12 hr battery disconnect yet? leave the neg terminal off for 12 hours
Old Jan 15, 2009 | 03:55 PM
Hi-TechG35's Avatar
Holy Batman return from the dead thread.
Old Nov 13, 2024 | 11:25 AM
jbliss's Avatar
g35 sport coupe
bump
Freeman186
Sep 6, 2023 10:07 AM
mattdg35
Sep 14, 2015 11:28 AM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Jnm07
Sep 5, 2015 01:16 AM
n2fooz
Sep 4, 2015 07:46 PM
