2300 rpm rev limiter
Old Oct 30, 2008 | 10:50 AM
cupidjuice's Avatar
today, at about 120mph my G coughed and now it won't rev higher than about 2300 rpm. Three engine lights are on: slip, VDC, and service engine soon. is there some sort of reset button or did I lose a sensor?
Old Oct 30, 2008 | 01:23 PM
miltoda's Avatar
you're in limp mode. Probably a sensor went out or something is wrong in the transmission. Does it shift only up to third gear?
Old Oct 30, 2008 | 01:26 PM
uf20wop's Avatar
crank position sensor?
Old Oct 30, 2008 | 02:25 PM
cupidjuice's Avatar
trany
Thanks for your answer.
The transmission does go through all the gears no problem. I will have it coded and see what comes up.
06g35
Feb 14, 2022 05:59 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
mbe32
Nov 13, 2015 11:09 PM
vamarris
Sep 26, 2015 12:56 PM
