I jacked my car up in the wrong spot
Old Nov 29, 2008 | 10:27 AM
nycityinsomniac's Avatar
Now the floor in my g is all raised up right under my feet on the drivers side. Has this ever happened to anyone? What is the best way to get it back down to flat again? sledgehammer? I have no idea. Thanks in advance guys
Old Dec 5, 2008 | 08:22 PM
kenchan's Avatar
yikes. i would pull up the carpeting to make sure there's nothing
under there and then tap it down from the top with a rubber
mallet.
then raise the car again and check for any cracks in the corrosion
protection.
Old Dec 5, 2008 | 08:24 PM
Mike Zajac's Avatar
mallet.
protection.
^^^^^^^^^ +1
Thats sucks man, good luck with that.
Old Dec 5, 2008 | 11:08 PM
Rodrigo's Avatar
remove all the carpet from the front and remove the drivers seat .
the more space you have to work with the better,
use a small ply wood about 8-10 inches long and hammer on top of it on the place where its is mostly raised, be patient and do a little at a time,
i fixed a friends M3 this way and you could not tell after i was done,
the metal in this area is quite flexible so like i said be patient and do it right.
Old Dec 28, 2008 | 02:22 PM
Gone-G's Avatar
rubber mallet, no sledge
Old Dec 28, 2008 | 03:40 PM
SDGeneralCounsel's Avatar
sorry, I can't help but giggle lol. Best of luck OP
Old Dec 29, 2008 | 10:37 PM
AIminiS10's Avatar
I see this post is old, but I had the same thing happen to me at a wheel/tire shop. The douches jacked my car up by the floor on both sides. I took it to a body shop and they tore the seats out and center console. Had to use body hammers/dollies to stretch the metal back to normal. It just takes a lot of time and patience! Good luck
Old Dec 30, 2008 | 04:25 AM
thanks guys
Xfactor
Dec 1, 2019 12:52 PM
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
DRG35R
Jul 31, 2015 10:23 AM
ClwMike
Jul 23, 2015 12:55 PM
