Brake Light not working?
Old Jan 14, 2009 | 01:04 AM
elayman's Avatar
they may have bypassed the cables to ur light if your car wasn't prewired or something if there is a prewire for spoiler.. anyways my brake light started working again yesterday??! i dont understand haha it definitely was not working for a week and a half.. I have an appointment on Thursday so hopefully they can check it out as well as some other problems with my power outlets
Old Jan 17, 2009 | 01:39 PM
fbpem1's Avatar
open your trunk and check where the black rubber is on the right hand side giggle it if the brake light comes on or if wierd things are happening your have broken wires in there, split it open and then resolder them and wrap them back up this is sort of common the issue i am talking about.
Old Mar 1, 2009 | 04:59 PM
RPL's Avatar
RPL
My rear break light is busted as well. I checked all the connections from my trunk to the light as best as I could and all the connections seem fine. Is there a separate fuse at all for the 3rd rear break light? Thanks.
Old Mar 1, 2009 | 06:03 PM
elayman's Avatar
My dealer said one of the rows of LEDs was out and must have shorted out the other one because it came back on for a day or so before I brought it in, but it wasn't bright at all
Old Mar 1, 2009 | 11:56 PM
jmueller's Avatar
If you look around at other semi-stock or stock G35 sedans (at least in Florida) almost ALL of the third brake lights are not working.. I think it has something to do with the heat because mine will work for the first 2-3 times i press the brake.. then it wont work anymore, maybe because the resistors heat up to much, i don't know.
Any advice on this would be great
Old Mar 2, 2009 | 12:58 PM
RPL's Avatar
RPL
Maybe it's a lost cause :\
Old Mar 5, 2009 | 11:20 PM
G-ealousy's Avatar
My 04 Sedan's Third Eye is not working. New owner, I haven't even got the plates for it yet. No warranty. I hope I find the answer on this forum. I've seen a few 1st gen sedans here in Denver without the 3rd eye working. I figured it was a well know, well documented issue but, searching for a straight answer has proven to be difficult...
Old Mar 6, 2009 | 07:45 AM
jmueller's Avatar
according to other topics on here, it is caused by a bad diode within the light's circuitry. Some people take out the light, and solder in a new diode or they simply by the new unit for 100$ at the dealer.. or pay the dealer 400$ to fix it. I believe the new unit has 2 LED bulbs instead of 6.
Old Mar 6, 2009 | 03:00 PM
G-ealousy's Avatar
Hey jmueller - gotta link? I was searching last night and couldn't find anything that specific... I read a lot of "Maybe the wire became loose" threads...
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
Lsantana757
Jul 20, 2015 09:08 AM
attarday
Jul 15, 2015 04:03 PM
