Like an xmas tree.
Old Jan 3, 2009 | 09:31 PM
suseJ's Avatar
Like an xmas tree.
Hi all, pretty new to g35d so not too efficient at using it yet, so apologies if this has been covered and I missed it.
'04 AT sedan, stock.
First off, I need new rubber and brake pads. I'm pretty certain that what I'm going to describe is related to these needs but it seems bizarre so I wanted to hear some opinions.
Bout a week ago, VDC Off, ABS and Slip came on and VDC (although not ABS) got disabled by the computer. I tracked it down to the brake pads being low, but topped off the fluid reservoir to fool the computer until I can replace them.
Today, my throttle pedal suddenly 'stopped working'. I could idle forward and reverse but could not apply power. The VDC Off, Slip and Service Engine Soon lights were on.
Not having any better ideas, I turned off the engine and restarted it. After that the throttle came back to life, but the SES light remains on.
Is this expected behavior for a brake pad issue or do I need to go into triage with the beast?
Thanks!
~suse
Last edited by suseJ; Jan 3, 2009 at 09:36 PM. Reason: Because trackpads are lame and cause the cursor to move accidentally.
Old Jan 5, 2009 | 12:12 PM
DKatman's Avatar
Hey there, Buddy.
I had read a thread talking about the same idea. I am not sure they ever got to the SES light coming on or not.
Here is the link to the direct response in that thread that might have info:
https://g35driver.com/forums/3756454-post4.html
Dave
Old Jan 5, 2009 | 12:43 PM
suseJ's Avatar
Thanks, DKatman.
Yeah, I'm not too worried. My impression is that the computer has some pretty tight tolerances. Between my brakes and tires (worn = diameter is not within spec?) I think I'm just pushing the envelope.
Yet, I'm eager to hear more from the g35d crew!
Old Jan 12, 2009 | 08:19 PM
Rallycraft's Avatar
Sounds like a throttle body / pedal position sensor issue.
Old Jan 12, 2009 | 08:22 PM
PAIXAO's Avatar
+1
Had the same issue with the same lights. My entire throttle body needed replacement.
Old Feb 5, 2009 | 07:59 PM
DKatman's Avatar
So what ever happened here?
Did you get it fixed? Or just start walking everywhere?
Dave
Old Feb 6, 2009 | 02:29 PM
suseJ's Avatar
The problem took care of itself after my next fill up. I've read that a loose gas cap can cause those symptoms. I guess the ODB code (P2135) is a fuel system catch-all.
Old Feb 6, 2009 | 02:45 PM
DKatman's Avatar
Good Deal then. That is the best kind of repair.
Dave
townsley
Jan 7, 2004 11:11 PM
