Resetting ECU = Better Gas Millage???
Old Feb 13, 2009 | 07:29 PM
  #31
Blue Meanie's Avatar
I get about 350 miles from fill up, to the little light coming on...
Old Feb 13, 2009 | 07:39 PM
  #32
istan's Avatar
My mpg gauge went from daily 13-14 to 19 when I reset my ecu...
Old Feb 13, 2009 | 09:00 PM
  #33
daman513's Avatar
Are you serious?? did it really work? and when you reset it did you drive the car hard or slow... and did you use the 12 hour battery disconect or did you do something else?
Old Feb 14, 2009 | 03:24 AM
  #34
tt88supraman's Avatar
Originally Posted by Gdup35sedan
i'll save you 12 hours... take off the negative battery cable, step on the brake pedal 3 times, then hook the neg cable back up. Works for me every time. If you drive your car aggressively, the ECU learns that and gets used to it, so it knows it has to use more gas, even when you're not bashing on the throttle. When you reset it, it goes back to normal until you drive aggressively for a while again.
-GP-
i did that 2night. lets c if theres any changes. i'm at quarter tank right now. i usually get 50-65miles at quarter tank. ill let u guys know if it worked for me.
Old Feb 14, 2009 | 04:18 AM
  #35
Thinkdiesel's Avatar
if u want better mpg dont get 20's, even then probably get u about 40 more miles
Old Feb 14, 2009 | 08:21 AM
  #36
istan's Avatar
I did the 12 hour disconnect. We were working on some things and left the battery unplugged over night. The next day, I had to reset all of my radio controls and started watching my MPG (I have a Z so we have the info meter, you would need Navi on a G to get it) and it skyrocketed.
I normally don't drive my car hard unless at an event.
Also keep in mind, I have a Vortech, Split Second, FMU, and 440 injectors, so needless to say, I was thrilled.
Old Feb 14, 2009 | 11:44 AM
  #37
daman513's Avatar
did you need a code to reset your radio or do you just mean you had to reset the stations?
Old Feb 14, 2009 | 04:30 PM
  #38
istan's Avatar
I meant stations.
Old Feb 16, 2009 | 10:02 AM
  #39
jetdoc's Avatar
I did the reset via pumping the gas pedal, will see what happens.
Old Feb 16, 2009 | 10:34 AM
  #40
SCXR's Avatar
I would check your O2 sensor(s). I'm not sure how many are on this car. It could be off but not so off that it's throwing a code.
I'm not saying resetting the ECU won't work, I just don't understand how it would. Isn't the ECU programmed to keep the a/f ratio at a specified ratio, regardless of how much gas you give the car? The only way I see this working is if the car decides to run lean after resetting the ECU which makes no sense to me. It can't limit the amount of air coming in.
I bought my car a couple of weeks ago and am getting 16 mpg with spirited driving. That's what I expected. I'm sure I can get better with unspirited driving without resetting the ECU.
Old Feb 16, 2009 | 03:17 PM
  #41
spinna001's Avatar
Originally Posted by JBV86
I dont need to go fast or drive hard.
I take my time and drive patiently to get where I need to go.
^^^^^^ thats absolutely right
Old Feb 16, 2009 | 03:59 PM
  #42
jetdoc's Avatar
no wonder you get 480 you granny drive the car lol like g35 man said were lucky if we get 220 on a tank... this is rediculous i only got 103 miles to a half tank again this is HORRIBLE man... gotta be something wrong with mine
Sounds more like there is something wrong with how you drive as opposed to the car itself,
Old Feb 16, 2009 | 04:36 PM
  #43
jetdoc's Avatar
Word.
Old Feb 16, 2009 | 06:26 PM
  #44
-GP-
that did not work for me. i still got 60miles from quarter tank. so i guess i have to disconnect the battery for 12 hours.
Old Feb 22, 2009 | 01:43 AM
  #45
05BlackG35x's Avatar
updates?
