Need help trying to get more hp without turbos or Supercharged
Old Feb 22, 2009 | 09:54 PM
lilDee's Avatar
Post Need help trying to get more hp without turbos or Supercharged
what should i do to get more hp !!! things like
Exhaust
intake
headers
and ect...please name the product and about how much hp thanks.
Old Feb 22, 2009 | 09:57 PM
bluemax189's Avatar
google motordyne. get the 5/16th spacer and mrev2 if you could. i didnt want to splurge that much since the baby is on the way so i got a non revup lower plenum. the spacer adds about 11-15hp, and the manifold the same. best bang for the buck there, minus nitrous of course.
Old Feb 22, 2009 | 09:58 PM
O HELLA OEM's Avatar
make sure you get a proper tune for all these breather mods
Old Feb 23, 2009 | 12:07 AM
BuckeyeInMI's Avatar
Exhaust
intake
headers
Use the Search feature and read. Also, try Google.
Old Feb 23, 2009 | 12:08 AM
llut5at's Avatar
+1 w/o a tune you can end up with an A/F ratio that is waaayyyy outta whack I had my car dyno'd the other day and i was running pretty lean and dyno'd low. I need to get a tune
Old Feb 23, 2009 | 03:26 PM
Infiniti Chica's Avatar
Would a difference in hp of 15-25hp be that apparent (unless you're on the track) to warrant investments >$100? Just asking.
Old Feb 23, 2009 | 03:48 PM
SCXR's Avatar
I think so but it comes down to what is it worth to you. I used to have a Toyota Matrix that I heavily modded. A friend thought it was foolish to put money into a car. He collected surfboards and paid BIG money for some of them. I think that's foolish.
Modding isn't smart from a financial perspective. I look at it as a hobby.
Old Feb 23, 2009 | 04:46 PM
You'll feel a 25HP difference. I added an OEM Z-Tube and K&N Filter and could feel the difference at 3500+ RPMs. Nothing crazy, but a nice boost, and that's not even close to a 25HP add.
Two part answer. First, you're not going to get a 15-25HP jump from $100-ish in mods. For $100-ish, get the Z-Tube. Second, if you focus on the best-bang-for-your-buck mods (Z-Tube, plenum spacer, etc.), you could add 15-25HP easily, but you're talking at least $300+ in mods, not $100-ish (spacer is around $200).
And like SCXR said, it all depends on what you want. Pure speed? Better sound (engine/exhaust, not audio)? Better handling? Appearance? All of these will have their own "best" scenario price-wise. Personally, I'm doing a mixture of speed and sound (adding a plenum spacer and a muffler), followed later on by some handling (new wheels/tires). The beauty of the G is there are lots of options out there to mod your car just the way you want it.
Old Feb 23, 2009 | 05:16 PM
Tollboothwilley's Avatar
intake, plenum spacer, headers, high flow cats/test pipes, cat back exhaust
you'll notice the difference if you do all those...
and a good tune on top of that should increase around 15-20 more
Old Feb 23, 2009 | 05:26 PM
Stillen intake with Z tube (I would wrap with heat shield tape also) ~$240 +5hp
Motordyne 1/2" spacer with Iso thermal upgrade ~ $300 +12hp
DC Headers ~$500 + 11hp
Kinetix, Fast Intentions or Berk HFC's ~$400-600 +8hp
Stillen dual/Borla cat-back exhaust ~$750-950 +15hp
These are estimates and are the gains people see over STOCK.
When combining all these mods you will not see +51 HP...although with a proper tune you might see something close to that at the crank.
You can find other things out there as well but you will pay...
Old Feb 23, 2009 | 07:44 PM
tampagsedan's Avatar
4.083 or 3.9 final drive will be the only n/a mod that will make your car significantly faster. Bolt ons and tune are nice but it wasnt untill I did the 4.0 gears that I was able to hang with and beat quicker cars such as e46 m3s and sti's. read up on gears on my350z.com
Old Feb 24, 2009 | 11:33 AM
Very intelligent answer Mr. BuckeyeInMI-- thanks!
Old Feb 26, 2009 | 02:31 AM
lilDee's Avatar
STILLEN intake with ztube and STILLEN 2ed gen catback exhaust http://www.vividracing.com/catalog/s...6-p-12464.html exhaust for 963.99????
Old Feb 26, 2009 | 03:35 AM
Exhaust can get crazy expensive, especially if you're replacing the cats. But you get lots of improvement for those dollars. Just like a person, a car has to breathe better to go faster, and that means inhaling and exhaling.
g.spot
May 9, 2016 10:54 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
9tray turbo
Sep 29, 2015 10:22 PM
ncg35guy
Sep 24, 2015 04:53 PM
