Sunroof won't tilt?
Old Apr 11, 2009 | 12:58 PM
stuntdevil's Avatar
Sunroof won't tilt?
My sunroof won't tilt anymore!
It opens and closes fine.
When i push tilt it goes up and then back down. Won't stay in tilt mode.
I tried reseting it.. no luck..
anyone have this problem?
my car is out of warranty
Old Apr 13, 2009 | 01:54 PM
stuntdevil's Avatar
any one?
Old Apr 13, 2009 | 02:49 PM
visibiliti's Avatar
Hmm, I have a similar but not duplicate problem. I made a thread about it awhile back.
My sunroof tilts, but then when i close it from tilt, it closes then immediately "bounces back" to the tilt position. the only way to "trick" it into closing is for me to stop it halfway down while closing, then wait a second, then stop it 1/4 way down, then wait a second, then close it all the way.
Similar, but different. I haven't solved my problem yet but someone gave me a tip to try let me dig it up.
k found it... https://g35driver.com/forums/general...f-problem.html
i should probably try his tip sounds easy... just never took the time because winter came and i wasn't using it then
Old Apr 13, 2009 | 05:16 PM
stuntdevil's Avatar
I tried resetting it, didn't work.
Old Apr 13, 2009 | 05:43 PM
Hi-TechG35's Avatar
^Sounds like one or two things...either the roof is off the track or the motor is going bad,
Dallsinghjr1
Sep 17, 2023 11:25 AM
Hogbone
Sep 28, 2015 06:44 PM
zcherub
Sep 10, 2015 12:03 PM
pasjr1972
Sep 1, 2015 10:17 PM
