have there been any UPDATES on our gask tank issues yet?
Old Apr 23, 2009 | 07:39 PM
erklep's Avatar
i know its been beaten to death but since the warm weather has been peeping its head, my tank has again been giving me issues with re-fueling. i was just curious if anyone had heard anything new on this issue or if anyone was brave enough to come up with fix themselves?
ive been on E for the past 3 days and im pushing my luck. car wont take any fuel again. im thinking of dropping the tank at work tomorrow and attempting to resolve this once and for all.
Old Apr 23, 2009 | 10:42 PM
kernel's Avatar
SEC > Big 12
do u mean besides the recall?
Old Apr 23, 2009 | 10:44 PM
erklep's Avatar
yes, besides the recall. the filler neck recall is not what is causing my issue. that was only for leaks.
Old Apr 23, 2009 | 10:51 PM
ttrank's Avatar
Grocery getter
Nope, I have only had this issue a couple times in 3 years. I have found that it is more a problem on the side of the fuel station system that pulls the vapors back in and getting the spout just right. We have the same problem with my wife's Mazda3 at a few gas stations around town.
Old Apr 23, 2009 | 10:57 PM
GEE35FX's Avatar
Are you sure it's not the shutter valve, there is a service bulletin for it. It was replaced on my 05 G35 because of the same symptoms.
Old Apr 23, 2009 | 11:02 PM
g35man04's Avatar
CLUB MODERATOR
I have it sometimes where I cant pump gas at all on my car...i have to re-insert the filling nozel time after time and eventually it will stay on
Old Apr 23, 2009 | 11:04 PM
erklep's Avatar
not the shutter valve. i replaced that twice with no results and i also tried removing it completly. i work for a nissan dealer and we have a free hotline for help.i called tech line and they are telling me the next step is to replace the tank. ive used consult to verify the vent control valve is working, even tried a new one just in case. then checked all evap hoses for leaks or plugs, nothing. removed filler neck and made sure nothing was jamming that either. it seems to be more sensitive in warm weather. it always gave me issues but i can slowly fill it during the colder months,now it just wont take ANY gas.
according to our service manual, there is a fill level valve that is in the tank and is non-replaceable. imo, that can really be the only other culprit. but just as tech line said, the tank will need to be replaced. just shy of 400.00 at employee pricing.
Old Apr 23, 2009 | 11:07 PM
erklep's Avatar
ive tried multiple pump at multiple stations all with no luck. ive tried various positions with the nozzle and it doesnt change a thing. im to the point of popping my rear seat up and pulling the fuel pump and just pumping directly into the tank!!! haha this is a nightmare.
Old Apr 23, 2009 | 11:08 PM
GEE35FX's Avatar
Here is the Service Bulletin # for the shutter Valve, I just looked it up and it applies to 03-05 G35 sedans and Coupes.
# ITB05-031
2003-2005 G35 AND FX; FUEL TANK DIFFICULT TO FILL AT TIMES
APPLIED VEHICLE(S): 2003-2005 G35 (V35) and (CV35)
2003-2005 FX (S50)
OOps I was posting this before I read the above. There is also another Service Bulletin for a different fix on the tank, I was just looking at it a minute ago.
Old Apr 23, 2009 | 11:10 PM
erklep's Avatar
# ITB05-031
2003-2005 FX (S50)
see above post.....thanks though. im afraid im looking at replacing the tank for this fuel level valve. or find a way to bypass it
Old Apr 23, 2009 | 11:12 PM
GEE35FX's Avatar
What about this service bulletin ITB08-041a
VARIOUS INFINITI MODELS; HARD TO FILL FUEL TANK
The fuel tank is difficult to fill more than ½
Old Apr 23, 2009 | 11:36 PM
erklep's Avatar
i really appreciate all the help but ive already installed the plate as well. but im glad that im getting some ideas here, that is why i posted this. mabye someone has a real/permenant fix for me
Old Jun 9, 2009 | 06:20 PM
erklep's Avatar
well i bit the bullet and put a tank in like techline suggested, still no luck. ive tested the evap system, vent control valve, canister, pressure sensor.... all working. new tank is in and still wont take. i tried pulling off the vent hoses right at the tank and still no luck. i called techline back to tell them that the tank had not fixed it and they said they would have to call me back b/c they didnt have any ideas at the moment.
Old Jun 16, 2009 | 05:30 PM
erklep's Avatar
so after countless headaches and numerous calls with infiniti/nissan tech line, after all the hours spent looking at the fsm and and all the time ive wasted and my co-workers have wasted, i finally found my issue. seeing as i had replaced and checked every single piece of the evap and fuel system except the filler neck, i decided to remove it and just take a glance. all looked well so i went over to the sink and filled it up with water and water dumped right back out. i knew that couldnt possibly be the problem. so i think to myself, "the issue must lie between the neck and the tank." all that is between the two is an 18 inch piece of rubber that goes above the subframe... ah what the hell. so i pull it down and take that over to the sink, fill it with water and what do you know? it doesnt pass through! i tried to fish a coathanger through, nothing. so i cut the hose open and find that the hose has a bladder liner inside that has collapsed. not visable from the outside but once i cut it open you can clearly see the blockage that was causing the pump to click off. what kills me is that this hose has been checked over and over and over and each time, overlooked. only b/c we were testing it with air pressure every time. the air would pass through and push the collapsed wall to the side, but it would not allow any liquid to pass by.
Old Jun 17, 2009 | 12:47 AM
05_SkylineSedan's Avatar
20 Year Member
Man, if you have discovered the cause of this vexing problem you are our HERO! This is BIG! The part is simply called the "fuel filler hose" in the service manual. Interestingly, there was a recall of this very part in late '05 due to possible cracking caused by "exposure to ozone"...
Great work - I hope this is the answer.
