Tail lights/Instument Panel blowing fuses::HELP::
Old May 1, 2009 | 09:01 PM
ShanesG's Avatar
Ok so the other day i noticed my intsrument lights not working as well as my taillights. So I located the fuse and say that it was blown. Replaced it and worked fine. Then that night they weren't working again so i replaced it again and it went out again. Now I haven't done anything to my tail lights or instrument panel so i donno why it's doing this.
I do however have the passenger side wire harness tuck, but i have everything apart right now and there are no exposed/cut wires so i have no idea what is goin on.
I've been searching and can't find anything on a wiring schematic. Does anyone know where i could possibly find one, or which color wires i should look for that come off the fuse box so i can follow it and see if i can locate the problem.
Thanks!!!
Old May 1, 2009 | 09:30 PM
ShanesG's Avatar
Lemme add the last time i took it apart everything seemed fine even drove around and they worked. Then they just went out. Could it possibly be a relay or something thats bad. I would think if it was a short the fuse would blow instantly!!
Old May 1, 2009 | 10:25 PM
Skaterbasist's Avatar
Retired SuperMod
Here's a few good service manuals for different components on the 2006 G35 Coupe. I noticed many of them have schematics for wiring. I'm not sure if it's gonna help you out but you can check them out here: http://x.infinitihelp.com/forum/loca...s.php?catid=22
Just register and you can download the service manuals.
Old May 2, 2009 | 06:07 AM
ShanesG's Avatar
uuuuppp thought it was fixed. worked fine for about 50 miles tonight then blew again. This is ridiculous!!!
Old May 2, 2009 | 09:07 AM
GreenGoblin's Avatar
The goblin resurrection
Shane how is the ground on the headlight harness that you tucked?
Old May 2, 2009 | 12:05 PM
Sponger's Avatar
6MT Brembo Coupe
Sounds like a short to me. Do you have any aftermarket electronic accessories that are tapped into that circuit?
Old May 2, 2009 | 03:49 PM
ShanesG's Avatar
All the grounds are grounded, and no accessories tapped it.
If i could just find out what wires to look for i can run them back and see...
Old May 4, 2009 | 12:20 PM
ShanesG's Avatar
bump...i hate electrical haha
Old May 4, 2009 | 10:43 PM
Blue Dream's Avatar
I drove ttrank's car solo
It could be a faulty ignition switch. The same problem has happened to me on 2 previous cars and that was the issue. It's worth checking out if nothing else seems to be causing it.
Old May 5, 2009 | 09:12 PM
acemallone's Avatar
Looking for the same solution, no tail lights and no centre console lights. I am having a feeling it is a relay
Old Nov 23, 2009 | 09:57 PM
humanerd's Avatar
same exact problem, any fixes?
Old Nov 23, 2009 | 10:04 PM
ShanesG's Avatar
mine was my sidemarker wires, they got ripped out and were touching and poping it. have you tried changing the fuse?
Old Nov 15, 2010 | 01:16 PM
hawaiinpunch's Avatar
Sorry to bring this thread back to life but I have the same problem somehow my passenger sidemarkers wires Got ripped out and know I have the same problems you had..did you ever find out what was causing the problem?
Old Nov 15, 2010 | 05:40 PM
ShanesG's Avatar
Read post above yours
Gabe83714
Oct 6, 2015 06:40 AM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
master111
Sep 25, 2015 08:32 PM
