Big power steering leak, please help asap...:(
Old Jun 9, 2009 | 10:14 PM
ShanesG's Avatar
Ok, so being dumped is not always FTW, this morning i noticed a small leak coming from under my car, saw PS was low, had to drive to LA and now its horrible
The fluid is coming our of the boot on the drivers side. Can anyone give me an idea how hard this would be to replace and or how much, i need it fixed like tomorrow. here's a pic
I'm not to familiar with the steering components so im not sure if i could just change the arm or the entire piece the arm goes into.
Old Jun 10, 2009 | 11:15 AM
pwebb's Avatar
the clamps that hold the boots on are very cheesy.
clean the area up nice with brake clean and try a worm gear clamp.
Old Jun 10, 2009 | 11:42 AM
GreenGoblin's Avatar
The goblin resurrection
I was going to suggest cleaning it all up, also double check all the lines that nore are cracked, cut or anything. Then refill and look under that car to see where it is leaking, once you drive it the mess is everywhere.
Old Jun 10, 2009 | 11:53 AM
ShanesG's Avatar
the leak is coming out of the boot. It was almost a constant stream it was dripping so much.
Old Jun 10, 2009 | 12:10 PM
Ralph0064's Avatar
...i agree with what the others said. Its leaking from the bellow. You can try and clean it up & try a new clamp but you may end up needing to replace the p/s rack assy.
not on G's, moreso on Lexus but everytime Ive seen one repaired, it always ends up needing the rack.
Old Jun 10, 2009 | 12:41 PM
ShanesG's Avatar
^Yeah after a lil research last night, that's what i figured...anyone know how difficult it is to replace?>? any special tools or anything?
Old Jun 10, 2009 | 05:13 PM
pwebb's Avatar
power steering racks on these cars are pretty easy.
rust makes it tough getting the u-joint apart from the steering shaft. when apart, make sure the steering wheel/column cannot turn. if it does, bad things will happen.
make a note on the position of the tie rods, so when it goes back together you will be as close to center as possible.
alignment ASAP it will be very far off.
Old Jun 10, 2009 | 07:35 PM
ShanesG's Avatar
^So what would i need to order? the full rack and pinion assembly?
Old Jun 10, 2009 | 08:50 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
the best bet would be to break it down and see exactly what the problem is. if it is replacing a single component like a o-ring, it may not be that expensive.
if you need to replace the entire gear assembly, it is $864
no idea on how hard it is to replace. but if this is your daily, than take it to a shop. i doubt if many people have had to replace this on their G or 350Z
Infiniti OEM parts
Old Jun 11, 2009 | 12:57 PM
ShanesG's Avatar
^Can you recommend any places around sfv?
Old Jun 11, 2009 | 04:03 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
i hear great things about PrecisionZ in Canoga Park
http://www.precisionz.com/
Old Jun 11, 2009 | 04:45 PM
ShanesG's Avatar
k, i'll check them out!
Old Jun 11, 2009 | 05:48 PM
Skaterbasist's Avatar
Retired SuperMod
That sucks Shane. Out of curiosity, did you notice the event that caused the leak? Or did it just happen out of nowhere?
Old Jun 11, 2009 | 06:24 PM
ShanesG's Avatar
nothing in particular that i can think of
i just noticed it tuesday morning, then it got really bad later that day.
If i had to guess i'd say it's a combination of being so low, and possibly somethings hitting it, also maybe when whatever i hit on the free hit that as well and fvcked up up and it just didn't really leak till the other day...who knows!
Old Jun 13, 2009 | 05:10 PM
ShanesG's Avatar
Anyone know if this would be a descent replacement
http://cpwstore.carpartswholesale.co...versal:0)&sv=0
