05 coupe power seat problem
Old Dec 10, 2009 | 07:35 PM
aosmdavid's Avatar
Hey guys,
I'm new to the whole G35 scene. I just bought an 05 G35 Coupe, and the power seats adjustments will raise the seat, but they will not lower them. All the other seat adjustments work fine. Do you think I will have to get a new switch? Any helps/tips would be appreciated. Thanks.
Old Dec 15, 2009 | 01:47 PM
pond's Avatar
im having the same problem aswell
Old Dec 21, 2009 | 11:59 AM
GrocryGettr's Avatar
Someone probably spilled coffee or soda on the switches. It's a common problem and nine times out of ten, you can remove the switches and clean the points with electrical solvent. Be very careful when doing this. Do one at a time, and make sure you have a clean work area because they are easy to loose.
Old Dec 23, 2009 | 01:16 PM
pond's Avatar
how hard is it going to be to take this apart
Old Jan 4, 2010 | 01:27 PM
If you have never worked with electrical switches before, then I would suggest letting a shop do it for you. We would only charge $75 per side to do this.
Old Feb 6, 2010 | 10:53 AM
Pratt's Avatar
haha yeuss go to the shop
Old Feb 25, 2010 | 05:46 PM
SanDiegoDrive's Avatar
OK I'm having a VERY similar problem. I have an 03' G35 Sedan and my passenger seat will adjust back, but not lean forward again...usually. Mine will SOMETIMES lean forward, but if I try again won't
So does this sound like I just need to clean off the controls?
Old Mar 1, 2010 | 03:04 AM
DosEquis's Avatar
^^^ it could be the controls, or maybe your tilt motor has taken a poop. one easy way to check to to go under the seat frame and tap on the tilt motor while you operate the
switch to lean it forward.. if it doesn't start working again, then its usually the switch
that has gone bad. If it starts working again, then it is the tilt motor that has gone bad and then you'll probably have to replace the whole seat frame if you want it fixed because i don't think you can get the seat motor by itself, but i could be wrong.
Old Mar 1, 2010 | 06:58 PM
nissan_driver24's Avatar
does the motor make any noises when you push the button to get it to go down? If it does then it could be that the gear is stipped.
Old Mar 4, 2010 | 01:51 AM
aosmdavid's Avatar
It doesn't make any noise at all, and sometimes it works. Then, if I try to move it again right after, it won't move at all.
si_driver
Interior
Jul 25, 2015 09:22 AM
brian_z
Jul 20, 2015 01:30 AM
