what tool is used to remove this ?
Old Oct 29, 2010 | 07:31 PM
berniEE's Avatar
does anyone know what tool exactly is used to remove this? thanks
Old Oct 29, 2010 | 07:47 PM
Canadian's Avatar
Canada, eh?
What/where is this?
Old Oct 29, 2010 | 07:49 PM
M3Tuner44's Avatar
is that on the steering wheel? It looks like it needs a torx socket with the middle indent.
Old Oct 30, 2010 | 01:15 AM
berniEE's Avatar
i thought it was a torx socket too... t-30 or t-40.. it doesnt fit and the pattern doesnt look the same. if you look closely it looks like a flower pattern not like the star pattern (torx)
Old Oct 30, 2010 | 02:04 AM
Itzmy04G35's Avatar
go check out what harbor freight has in stock...or lowes/homedepot
Old Nov 5, 2010 | 10:57 AM
HangUp n' Drive's Avatar
I can't see the pic, but the "middle indent" sounds like a security bit of some sort.
You might want to search for a serrated bit they are similar to Torx but not quite the same. Snap On, or Mac tools have a lot of specialty stuff $$. Also here is a link to some security bits.
Amazon Amazon
Old Nov 5, 2010 | 11:40 AM
Rodrigo's Avatar
looks like torx socket , to me too
Old Nov 5, 2010 | 08:57 PM
I can see the picture now, I am pretty sure this is a special nissan tool, (Kent-Moore J-42057 or J-44615 sets), way expensive, but a tamper proof Torx should be close enough to get it off. Or a regular Torx if you grind the center pin out of the bolt.
Old Nov 5, 2010 | 09:20 PM
berniEE's Avatar
Really damn... What size torx would you say I tried t-40 which was too small.. =( thanks for your input.
Old Nov 5, 2010 | 09:45 PM
I guess a T-45 of T-50 what ever is the largest you can fit in it. It won't fit precisely. Try this link
http://www.350z-tech.com/zwiki/Steer...ontrol_Install
It doesn't look like it will come off easily,(loctite) and you will probably want to replace the bolt with a standard one. Be careful around those airbags, they are extremely powerful.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
DRG35R
Jan 31, 2016 07:14 AM
dcsbh1
Oct 1, 2015 03:15 PM
