Upper oil pan
Old Dec 10, 2010 | 05:35 AM
05 sedan's Avatar
I just had the same problem with my 05 they wanted 780 bucks to fix it. my leak was big. I also live in vegas. I drove the car to Cali were i got the job done for 200.
Old Dec 16, 2010 | 12:28 PM
GrocryGettr's Avatar
Originally Posted by toymachine2009
Thanks. They said specifically that it will be $720 to take out upper oil pan and to reseal it with cocking and put it back..
Also have the problem when my car is idleing at like a red light or stop or whatever the heat goes from blowing 90 degree heat to cold air. They tried bleeding it but no success to getting the air pocket out.
Your thermostat is most likely bad. Just replaced one yesterday and it fixed the problem.
We charge $525 to reseal the "upper oil pan".
seagrasser
May 3, 2022 09:43 AM
g.spot
May 9, 2016 10:54 PM
alessandro
Oct 8, 2015 09:29 AM
yosip1115
16
Sep 28, 2015 04:14 PM
