Random no start/ blank gear indicator
Old Dec 20, 2010 | 05:41 PM
DuItLikeDu's Avatar
Exclamation Random no start/ blank gear indicator
What a great time to have no car :frusty:. The past few weeks I've been getting a random no start on my '03 G35 sedan. When this occurred it wouldn't start but all other electrical items such as the radio, heat, etc. would work. I also noticed when this happened that the gear indicator would go blank and sometimes leave the A/T check light on. If I left the car for an hour or so it would start up without a problem but then as the weeks went by the 'start up delay' inceased from hours to a day. Transmission shifts smoothly btw. Anyway the problem occured yesterday and now the vehicle is here stuck. It won't start at all. The battery is 2 months old and was checked and is good, starter was changed and positive and negative connections checked, obviously with this blank indicator and A/T check light on it has to be something more than that. For the past few days I've been googling around to see what I can find on this issue, and in most forums I just see the problem post like mine with no response to follow or follow-up if the problem has been fixed. If ANYONE is familiar with this issue and can give me an idea of what may be going on. I'm also in Brooklyn, NY and would like to get it towed to a recommended shop on Wendesday to get this issue taking care so if anyone can recommend me to a shop who's mechanic(s) are familiar with Infinitis it will be greatly appreciated and I will definitely consider it because I'm am tired of these random mechanics guessing as to what the problem is. Thanks.
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
vamarris
Sep 26, 2015 12:56 PM
