'06 G35 Sedan Heater Problem
Old Dec 26, 2010 | 09:49 PM
mikewortel's Avatar
Today I noticed something weird:
When I am at idle, especially at a long stop light or something similar, the heater does not make hot air through the vents, even with the temp turned all the way to 90 and the fan cranking as fast as it will go.
But as soon as I start reving the engine, or simply start moving fast, the cool air turns hot pretty quickly.
Then when I come to a stop and it idles for a bit, it goes cold again.
Please note that all of this occurs when the engine is plenty warm. Does anyone have any suggestions or any experience with this? I just hope it isn't expensive to fix.
On a side note, the A/C definitely works fine. There just seems to be something preventing hot air from the vents when the engine idles at low RPM.
The car is a 2006 G35 Sedan with 48K, and It actualy received a new engine about 700-miles ago due to a con-rod bearing defect....
Old Dec 26, 2010 | 10:01 PM
noooorb's Avatar
What is the outside temperature when this happens?
Old Dec 26, 2010 | 10:32 PM
mikewortel's Avatar
I knew i forgot something...
I live in Orange County, CA, and it was 53 degrees today when I noticed it.
Old Jan 6, 2011 | 06:20 PM
MarkG's Avatar
You have air in the cooling system. There is a bleeder screw near the firewall on the passenger side. Make sure your coolant overflow tank it topped off too.
But since you have a new engine installed, take it back and have them do it right.
Old Jan 7, 2011 | 02:19 AM
Wannabe6MT's Avatar
-MN G Crew-
Mine does this too.... I wish their was a DIY how to fix it lol I don't understand peoples directions haha
Old Jan 7, 2011 | 02:54 AM
thescreensavers's Avatar
Mr.202?
^ the bleeder screw? I Believe bythabay has a video on it
Old Jan 7, 2011 | 10:26 AM
MarkG's Avatar
Yes, here's the video
Old Jan 7, 2011 | 11:36 AM
Wannabe6MT's Avatar
-MN G Crew-
So basically, you just turn the little screw to relieve air?
Old Jan 7, 2011 | 06:21 PM
Mr.202?
^ Yep but I believe the car needs to be on, and coolant will spill, so you probrally going to have to buy for 8bucks a premixed bottle.
https://g35driver.com/forums/engine-...loud-boom.html
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
attarday
Jul 15, 2015 04:03 PM
