Car is not going into gear help!!!!
Old Jan 15, 2011 | 11:08 AM
d3zzy718's Avatar
Angry Car is not going into gear help!!!!
so today i was installing a double din into my console, the car was for but i but it into neutral to better maneuver the din in. Then after i got it in i tried to shift back into park and it would not budge. then i manually had to take back off the console and push down on a tab to get it back into park.. Now its not going into gear please help i have a 06 X sedan
Old Jan 18, 2011 | 12:39 AM
lechols155's Avatar
did you remove the shift ****. not sure about infiniti mine is mt, but on many cars the shift **** has to be put back a certain way
Old Jan 18, 2011 | 02:38 PM
drivessidewayz's Avatar
If I understand you correctly, you put the car in neutral an shut it off there. Often automatics have a little tab you can remove somewhere to stick a key or other long, thin piece into in order to release the shift lock mechanism and enable you to shift it while the vehicle is turned off, or sometimes when it refuses to move into a specific gear.
Run on sentences ftw.
Old Jan 18, 2011 | 10:36 PM
Hossmaxima's Avatar
This happened to me when I had my maxima. As stupid as it sounds when I picked my car up after an install I shifted into gear it was fine and then it was giving me trouble I got home and barely got it into gear, I got back to the shop somehow and what does the installer pull out? His little screw driver left in the shifter under the boot, lol. Worth to check.
Old Feb 7, 2011 | 10:06 AM
Sandman1278's Avatar
My G35 has a little "shift key" or "shift lock" tab on the left side by the boot. A little black square tab that you can lift up. Might look into that little guy as well. I personally have never used it but it obviously has something to do with the shifting but would be rarely used.
arora_g35
Apr 16, 2026 02:52 PM
Blakearold
Aug 19, 2015 10:20 AM
DRG35R
Jul 31, 2015 10:23 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
