light metal scrape sound. Help please!
Old Mar 14, 2011 | 10:06 AM
B_Lam's Avatar
Hey,
it's happened twice... I heard it once when i went under a tunnel on a local street and once after leaving my house on my street.
As I drive, randomly i'll hear this sound like as if someone is holding a metal stick or metal bracket and scraping on the floor as i drive. It sounds like it's coming from the passenger side but not sure if it's front or rear.
Has anyone ever experienced this before? I get paranoid about my car making noises because i don't want anything to break down on me and then i'm stranded or have to end up towing my car with the hassle.
Please help me. Thanks everyone.
Old Mar 14, 2011 | 02:02 PM
B_Lam's Avatar
anyone?
Old Mar 14, 2011 | 07:40 PM
bigwilly's Avatar
Have you looked under you car? Maybe its one of the plastic under carriage trays that is dragging.
Old Mar 14, 2011 | 09:06 PM
B_Lam's Avatar
Hey, yeah i looked under my car and none of that plastic is hanging. Sounded like metal... like a screw driver dragging on the floor.
Old Mar 15, 2011 | 04:45 PM
saywat?'s Avatar
maybe brake pad indicator.
Old Mar 15, 2011 | 07:27 PM
vq39hr's Avatar
im not 100% but it might be your wheel bearing. if the sound gets worse, then you may need to replace your hub. drive around with your windows down, take a couple of turns, if the sound worsens while turning, then it may be your wheel bearing. if its your right front wheel bearing, the sound will worsen when you take a left turn and vice versa with a right turn. hope this helps.
Old Mar 15, 2011 | 07:32 PM
first post? ^
try to record the sound?
Old Mar 15, 2011 | 11:30 PM
B_Lam's Avatar
Thanks guys for the help. I'm gonna wait a little bit till i hear it more often. As of right now, it only happened twice and very randomly. Can't record it if i don't know when it'll happen... and it only happens for like a few seconds. I'm hoping its my brakes and not my wheel bearings. I'm also going to check my brake pads to see the life on them. Thanks everyone! Really appreciate it.
Old Mar 15, 2011 | 11:58 PM
vq39hr's Avatar
Originally Posted by iseechriss
first post? ^
yeah i just joined the forum, but im am very familiar with nissans/infinitis. im not just typing random stuff trying to look cool.
Old Mar 16, 2011 | 05:15 PM
saywat?'s Avatar
^lol
Old Mar 17, 2011 | 12:50 AM
05DGx's Avatar
If I had to guess I'd say you need new brake pads. There's a metal clip that serves as a wear indicator on the pad, and as the pad wears down, the clip will scratch against the rotor and make some noise to let you know. This happens whenever the wheels are moving, it doesnt matter if you're braking or not.
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
jdubin94
Sep 1, 2015 12:17 PM
Frostbite91
Aug 20, 2015 07:20 PM
linedr89
Aug 17, 2015 05:11 PM
Jay 21
Aug 5, 2015 04:53 PM
