RPM fluctuation after plenum spacer install -need help asap-
Old Mar 18, 2011 | 09:36 PM
dphillips2011's Avatar
I just installed by plenum spacer, and at idle the RPM's will be at around 650 (this is normal, right)? then they will drop about 100rpm's and vibrate a little then pick back up.
Is this normal?
also, is that thing supposed to SCREAM past 5K?
Old Mar 18, 2011 | 10:20 PM
Heist.'s Avatar
sounds like a leak.
Old Mar 18, 2011 | 10:23 PM
WhosRich's Avatar
Originally Posted by Heist.
sounds like a leak.
+1. Check all bolts and hoses.
Old Mar 18, 2011 | 10:27 PM
kennymo's Avatar
yes its supposed to scream past 5k. my car is actually quite a bit louder because of the spacer after about 3200 rpms
Old Mar 18, 2011 | 10:28 PM
kennymo's Avatar
oh and yea you have a vacume leak
Old Mar 19, 2011 | 12:34 AM
SxExCx's Avatar
I am 90% sure that the rubber ring that goes around your oil cap is wedged between the spacer and the plenum which is causing a vacuum leak.
Old Mar 19, 2011 | 11:03 AM
I just went out and looked, and you are 100% right. God damnit...
I even read about being careful with that too. there is a piece that is maybe a tenth of an inch wide and an maybe an inch long wedged in there. the top is torqued down pretty good, would that little tiny piece be able to cause a leak?
If so, i'll go out and rectify it right now
Old Mar 19, 2011 | 12:02 PM
Mr_pharmD's Avatar
the rubber piece around the oil cap would be my guess.
Old Mar 20, 2011 | 12:31 AM
the rpm's have been stable at 650 all day today. Could I be safe?
Old Mar 31, 2011 | 09:35 PM
strykez's Avatar
for sure vaccuum leak. spray some watch on that area and if your rpms change then you know its there
G35VSHNG37
Oct 25, 2015 08:43 PM
CoupeObsession
Aug 17, 2015 01:05 PM
Raven7
Aug 14, 2015 04:40 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
