Raising Idle?
Old May 13, 2011 | 12:07 AM
Jbean Green's Avatar
Raising Idle?
I have a vortech v-2 supercharger, at low idle (800RPM) it has the annoying rattle. I was wondering if I would be able to raise the idle to 1000RPM so it would go away. I contacted vortech, and a lot of people have complained about it, but there is no fix. How would I raise it if possible, can I do it myself or does Nissan need there computer to change it.
I haven't researched this to much, but what would the adverse reactions to raising the idle be?
Thanks a bunch
Geoff
Old May 16, 2011 | 07:41 AM
EL-EE-ES's Avatar
nissan/infiniti can raise the idle with the consult computer/program...
is your car tuned?
Old May 16, 2011 | 01:34 PM
Yes i have a piggy back ecu, infiniti and nissan told me its impossible unless i had a 1990 so i told them all you need to do is use the consult tool. Then they pretty said we cant do it over and over.
Is there a dealership in the states that has done it, i would like to get a phone number and talk to them. Then i can go into the dealership here and tell them whats what.
Old May 16, 2011 | 02:07 PM
I called metro infiniti in california they said it was possible but it would throw a check engine light. I know what they mean cause the drive by wire wouldnt be set to what it needs to see. is this the case?
Old May 17, 2011 | 03:22 AM
Silencer_0's Avatar
Can't your tuner raise it for you?
Old May 17, 2011 | 02:17 PM
If I had a tuner...
Old May 17, 2011 | 02:55 PM
Silencer_0's Avatar
No local tuner shops around you? What state are you in?
Old May 17, 2011 | 02:57 PM
I'm in Canada.. Calgary, Alberta and the tuning scene is pretty non existent. :-/
Old May 19, 2011 | 01:05 AM
There must be someone on the forum that's had this done.
Old May 19, 2011 | 02:46 AM
Sylvan lake V35's Avatar
At most of our alberta meets Randy I think his screen name on my350z is can350z maybe someone can confirm that...but he has consult and was doing 2deg timing advances and I would guess he could do the idle increase if consult can do it. He used to advertise on kijiji as well not sure if still does he was from red deer but I think he lined up a bunch of guys that wanted advances then went to Edmonton or Calgary.
If not Lightspeed innovations in RedDeer is supposed to be getting uprev this summer.
Old May 19, 2011 | 02:49 AM
Yea if you can confirm that, it would be a huge help. Ill see if I can find him on the other forum tomorrow.
Thanks a bunch.
See you at the next meet
Old May 19, 2011 | 02:51 AM
It is can350z over on my350z. His name in Randy.
Marlin84
Apr 1, 2020 12:52 PM
vamarris
Sep 26, 2015 12:56 PM
Jnm07
Sep 5, 2015 01:16 AM
