From Russia with Love to G35 Coupe 2003
Aug 15, 2011 | 12:19 PM
Hi, my name is Ivan, I'm from Russia. Sorry for my English being bad. I couldn't find a solution on my problem. I recently purchased a G35 Coupe 2003. My parking lights do not work properly. The car owner who had sold me the car didn't know anything about this problem. Need help - what to do with parking lights. Thank you.
I also have a question about the fuses. I simply can't understand how they work. On the fuses blocks there are abbreviations I do not understand.
Reply 0
Aug 15, 2011 | 02:41 PM
Quote: Hi, my name is Ivan, I'm from Russia. Sorry for my English being bad. I couldn't find a solution on my problem. I recently purchased a G35 Coupe 2003. My parking lights do not work properly. The car owner who had sold me the car didn't know anything about this problem. Need help - what to do with parking lights. Thank you.
I am sorry I can't be much help to you here. I know that the whole strip does not light up from top to bottom. Check the bulbs.
What I can tell you is that your English is about 10 times better than people who speak it natively. Best of luck to you, Ivan.
Reply 0
Aug 15, 2011 | 11:10 PM
Quote: I am sorry I can't be much help to you here. I know that the whole strip does not light up from top to bottom. Check the bulbs.
What I can tell you is that your English is about 10 times better than people who speak it natively. Best of luck you, Ivan.
Ok, I'll try to check the bulbs.
May be the case in the fuses?
We also have people who speak Russian bad ))) Thank you.
Reply 0
Aug 15, 2011 | 11:42 PM
тоько одна не работает или обе?
Лампочки на бампере такие же самые. Ели те работают провер ими лампочки в фарах, в противном случае это предохранитель, но врядле
Reply 0
Aug 15, 2011 | 11:50 PM
MIght just be the bulb
And as always, Have a nice day.
Reply 0
Aug 15, 2011 | 11:55 PM
Обе не работают. А как в фарах лампочки в этих габаритах вертикальных вытащить, я не совсем понимаю) В бампере в переднем габариты работают.
Both parking lights do not work properly. Need some help to get these parking light bulbs out from headlights. It should be mentioned that bumper lights work properly.
Reply 0
Aug 15, 2011 | 11:57 PM
Thank you. I'll try to check it out. Have a nice day ))
Reply 0
Aug 16, 2011 | 11:58 PM
It is necessary to remove fender protector to change the parking light bulbs?
Reply 0
Aug 17, 2011 | 01:10 AM
Quote: Обе не работают. А как в фарах лампочки в этих габаритах вертикальных вытащить, я не совсем понимаю) В бампере в переднем габариты работают.
чтоб достать те лампочки нужно снять нижний подкрыльник. Их можно достать только с низу. Bесь подкрыльник снимать не обязатально, можно тоько ту часть которая прямо под фарой, от низа бампера не обязательно откручивать. Там обычные 194 лампочки, по крайней мере они идут под таким номером в штатах. Коннектор на лампочках такой-же ка и на тех которые в бампере.
Reply 1
Aug 17, 2011 | 02:17 AM
Quote: чтоб достать те лампочки нужно снять нижний подкрыльник. Их можно достать только с низу. Bесь подкрыльник снимать не обязатально, можно тоько ту часть которая прямо под фарой, от низа бампера не обязательно откручивать. Там обычные 194 лампочки, по крайней мере они идут под таким номером в штатах. Коннектор на лампочках такой-же ка и на тех которые в бампере.
ООО Спасибо большое! Thanks a lot!
Reply 0
Aug 18, 2011 | 05:30 AM
THANKS A LOT TO ALL!
I had to bend out the fender protector and get the bulbs!
Reply 0
Aug 18, 2011 | 05:34 AM
sorry it was double post
Reply 0
