AWD Flashing ? why
Old Sep 12, 2011 | 01:08 AM
Minki's Avatar
AWD Flashing ? why
I have a 2004 g35 x and the AWD light keeps flashing / blinking
starts when i drive about 10 mins or so
i recently put on rims which are wider tires
245 front
275 back
I got my tires re balanced and still same problem, whats wrong
Old Sep 21, 2011 | 01:14 PM
Crzyazzpolak717's Avatar
I would def. start by swapping back to the other set of rims to see if thats causeing the issue. May be if the diameter of the tire is bigger then stock the computers calibration doesnt match and throws the light on. After that you gotta get someone with electrical diagnostic skills to look at it.
Old Sep 21, 2011 | 05:53 PM
william747400's Avatar
Don't think staggered wheels are recommended for AWDs
Old Sep 21, 2011 | 05:57 PM
NorthDakota's Avatar
What are full tire specs. and rim sizes?
Old Sep 28, 2011 | 01:52 AM
vigman's Avatar
All 4 wheels need to be rotating at the EXACT same speed... put your stockers back on & try it .
Mike
Old Oct 2, 2011 | 10:04 PM
G35xTurbo's Avatar
It's probably your staggered tire setup. Just try swapping back to your stock setup and I bet it goes away. Then sell those tires and run the same size tires all around and you'll be fine more than likely.
Old May 2, 2012 | 11:14 PM
ARB_MNY_G35x's Avatar
Tires must be same size bro.. I have the g35x and staggered rims.. Ur good as long as ur tires are same size.. Good luck!
Old May 14, 2012 | 08:57 AM
G35xTurbo's Avatar
Tires need to be the same DIAMETER. That's the key. Use this calculator when determining the diameter of your tires. I currently run 18 x 8.5" wheels front, 18 x 9.5" wheels rear with 215/45 18's up front and 245/40 18's in the rear and have no problems. Those diameters put me within 1/10th of a percent difference from front to back. Hopefully that helps.
Old Apr 17, 2015 | 06:34 PM
drifterxG's Avatar
www.willtheyfit.com
Old Apr 19, 2015 | 10:17 AM
TurTLe*'s Avatar
its amusing how you answered your own question in your first post.
Do your homework on staggered tires, you can run them but they have to be an exactly size.
I'm staggered =P
Old Apr 27, 2015 | 10:29 AM
Mustang5L5's Avatar
245 front
275 back
What's the full tire size?
You need to make sure the tires are the same OUTSIDE DIAMETER otherwise the AWD system will error and the light flashes.
If this is the case, you need to swap tire sizes around so the front and rear diameters are the same. Really no way around this with the AWD models.
Old Apr 27, 2015 | 11:07 AM
yosip1115's Avatar
Flashing AWD means T case temp is high beyond threshold. Bad things. Change your T case fluid too...
Old May 2, 2017 | 12:15 AM
Harman Sekhon's Avatar
Flashing AWD light
I have the same problem but my tires changed from 225/55R17 to 235/35R20 in the front and 255/35R20 in the back which didn't seem to be much of a difference. The back tires are .3 bigger than stock and front ones are .2 smaller so a total of .5 difference in total. Could this be the same problem for me or should i just try by getting the fluid changed?
Old May 2, 2017 | 12:33 PM
Mustang5L5's Avatar
Going off memory, but if I remember, the FSM states tire diameters needs to be off by no more than 0.1".
So 1/2" difference is pretty significant. You need to get your tire sizes pretty much exact in size. AWD is pretty sensitive to this.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
Thebaws11
Jul 2, 2021 11:36 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Vqalexisz
Oct 14, 2015 12:48 AM
