left blinker faster than right
Old Nov 18, 2011 | 11:14 PM
sandaluv's Avatar
hey guys got my car back from bodyshop today . they did a headlight restore but tonight i noticed left blinker and left fog light out. also the left arrow in dash is going way faster than right . would a restore cause something to go haywire in headlights. btw i have 05 sedan. thnx in advancel
Old Nov 19, 2011 | 01:20 AM
05_SkylineSedan's Avatar
20 Year Member
I'm not positive but I think the speed will change if the load changes. In other words, if your front blinker bulb is not connected or has failed it could cause the rear and dash indicator to blink fast. Hopefully the body shop just forgot to reconnect them?
Old Nov 19, 2011 | 02:59 AM
G35SedanGrn's Avatar
Gotta change that blinker fluid every 5k miles dude....
On a real note, ur signal bulb it out, change it & it should be fine.
Old Nov 19, 2011 | 09:32 AM
sandaluv's Avatar
Thumbs up
haha!! thats it? i thought it be something more serious. thnx to both
Old Nov 19, 2011 | 09:35 AM
sandaluv's Avatar
makes sense now. thank you and appreciate quick reply
Old Nov 20, 2011 | 10:16 AM
sandaluv's Avatar
someone at the bodyshop pulled 2 bulbs from my car when it was disassembled. i called the owner and hes gonna replace them for me. makes me wonder what else they removed from my car quick question : are all the bulbs in the unit supposed to be same color b/c the city light bulb is yellowish thnks again guys
Old Nov 20, 2011 | 02:19 PM
20 Year Member
Oh, you wanted the bulbs back in? D'OH! They must have removed the entire headlight assembly from your car to do the "restore".
Not sure what you mean by "city light" but if you're talking about the low-beams then they should look identical in color or the shop may have switched one of your HID bulbs. NOT GOOD.
Below is a list of the stock bulb specs and what the headlight assembly looks like. Be sure they have put back both of YOUR HID bulbs and at least a matching pair of halogen and parking/turn indicator bulbs. Turn on all the lights before you leave their shop.
Attached Thumbnails left blinker faster than right-bulbspecs.jpg   left blinker faster than right-headlight.jpg
Old Nov 20, 2011 | 02:46 PM
sandaluv's Avatar
yeah not cool huh? I guess its the low beam like you said. they removed headlights for sure. I'm considering pulling the good side headlight and checking part numbers. the more I think bout this the more aggravated I get.
Old Nov 20, 2011 | 08:05 PM
calm down, we do have a city light, stock the lowbeam should be white the "fog" should be a yellow, the city light should be a neutral yellow color & turn signal should be orange/amber.
Old Nov 20, 2011 | 09:01 PM
sandaluv's Avatar
im calm! im calm! haha ok so 1 side is good. I got white on top. yellow on bottom and blinker is amber. they only removed 2 bulbs.
Old Nov 21, 2011 | 08:08 PM
sandaluv's Avatar
so I went back to the shop today and they replaced my missing bulbs. my theory that they took them off mine to put on another car was dismissed when I saw the Guy pull out a box w hundreds of bulbs. they simply forgot to put them back in I guess. btw. all 3 bulbs were clear/white. thnx guys
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
edwinisdumb15
SOCAL Meetings & Events
Mar 4, 2016 10:45 AM
dcsbh1
Oct 1, 2015 03:15 PM
