Stop lamp fuse keeps blowing & VDC, SLIP & ABS lights on?..
Old Feb 9, 2012 | 09:05 PM
Project 04's Avatar
Question Stop lamp fuse keeps blowing & VDC, SLIP & ABS lights on?..
I'm in need of some help on this one guys... My stop lamp fuse keeps blowing?... My car starts, but when I press the brake to take it out of park, my stop lamp fuse blows and the VDC, Slip & ABS lights come on?... Any thoughts on this one would be great!
Old Apr 20, 2013 | 11:17 PM
nascarbuff17's Avatar
Fuse blows intermittently, sometimes instantly, sometimes it will last for weeks. VDC + ABS + SLIP light comes on and voila...cannot shift out of park. Pads & rotors fine, break fluid is topped up. 04 G35 with no wing. Trunk also will not open, which may be a related issue. I've read it might be where the wires go through a grommet into the trunk. Where is this grommet? Thanks, I've been unable to find a solution on other posts.
Old Apr 21, 2013 | 11:48 AM
05_SkylineSedan's Avatar
20 Year Member
Trunk wiring harness problems? Check for stripped or broken wires as they pass through the hinge area.
nettcar
Aug 25, 2024 11:59 PM
Mry
Mar 3, 2023 01:03 AM
Wayne9011
Aug 17, 2015 01:24 AM
Danielek
Aug 11, 2015 09:33 AM
Wayne9011
Jul 27, 2015 11:25 AM
