where does this go???????
Rebuilding my front end after a nasty accident. I've tried to keep track of where things went, but it's been a year, and on these 2 items I'm confused. First - I assume is a Hood/closed sensor, and the next I have no idea. My rad support was the main component broken so I'm sure both bolt on there. Just need to know where and in the case of the aluminum piece, what it is would be good info.
thanks. wilracer07@yahoo.com
Damn. Means I'm missing the bracket. No chance of finding one? Will my G work properly without it? BTW, Thank you. The other part I couldn't post even tho I have a pic. It's metal and seems to be the end of a wire line. 2 bolt holes and L shaped in cross-section.
Sorry to hear about your wreck. That switch is part of the vehicle theft alarm and as far as I can tell only completes the circuit when the hood is open. Meaning, you should be able to unplug it and operate the car normally - just the hood wouldn't set of the alarm...
Try making the pic of your other part smaller to be able to upload it...
That is an ABS crash sensor and it goes in the front by the hood latch and those other plugs are for your horn
Texas I tried some online translations and non could translate it. What does it mean?
I know caution and seatbelt and helmet(head)
Here's the somewhat cryptic illustration from an '05/'06 service manual. You may actually need a new sensor if you had a front-ender. Manual says if you drop it you can''t use it...
Good luck with the rebuild.
OK. Thanks a lot guys. I will look into simply buying a new one while Everything's still exposed. i was hoping it would become obvious once my Rad Support comes tomorrow but not sure I woulda guessed that.
Just a shot in the air but thought I'd ask if anyone knows the name of this body panel. Not life or death. but it needs to be replaced. Thanks again.
Ok, Thanks again. I can start there pricing it from Infiniti, where I assume I'll have to get it, but only after some strenuous Googling. There's going to be a point where this annoying thing is my main problem when the front is buttoned up.
So thanks to all that helped answer these dumb questions.
BTW. Update, Just got off the phone with my local dealership. No idea what a rear fender extension was but I described it to him. No luck. He told me they don't carry parts like that so guess I'm SOL for now.
I recommend finding a good body shop for those bits you can't do yourself. The pros can do amazing things with whatever you throw at them, including, most likely, repairing that body panel. Funny, the shadows in that photo make it look like the rear fender is whiter than the doors or the bumper!
It's worth getting it back on the road. Good luck.
http://infiniti.sewellparts.com/part...edan-2004.html
You get a g35driver discount if u sign up on there site..
