2003 G35 Coupe AC compressor failure
Old Jun 1, 2012 | 11:33 AM
N-tity15's Avatar
Alright so I bought a used G a few months ago. Since I've had it I ran the AC maybe 3 or 4 times and it worked just fine. Probably went a month without running it and then all of a sudden it starts running hot. Pressure was in the system so I fig I had freon. Took it into a shop and they flush and filled it to no avail. Diagnosed me with an internal compressor failure, needing a compressor, dryer, and expansion valve. My question is, if they evac'd the system wouldn't that have cleaned out any metal shavings or debris from the dryer and EV? Could I just replace the compressor without fear of contamination. I haven't touched the AC since the evac.
Old Jun 1, 2012 | 01:01 PM
DaveNYC's Avatar
Before all that let me ask you are you running stock headunit, and if so has it been working such as radio/CDs and such? My A/C Started blowing hot air and I don't hear the compressor engaging because my headunit went so I'm doing a DD. Usually when the Headunit goes in our G's it affects our A/C controls.
Old Jun 1, 2012 | 03:07 PM
N-tity15's Avatar
I replaced the stock unit with an aftermarket dash kit which had ac controls. It originally had the dead unit with the ac stuck on auto climate control when I bought the car.
Old Jun 1, 2012 | 03:09 PM
DaveNYC's Avatar
Oh ok that sucks then bro goodluck. I don't much info aside that as far as the questions you're asking.
Old Jun 1, 2012 | 03:31 PM
N-tity15's Avatar
Preciate it, yea sux man. I got two cars, no ac in either one.
Old Jun 22, 2012 | 03:31 AM
SUMATIC's Avatar
If you change your compressor it is recommended to change your filter dryer.
TWASkyliner
Feb 8, 2020 08:00 PM
R350k5
Oct 1, 2015 08:41 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
Chattzx
Jul 17, 2015 11:23 AM
