Check engine light code
Old Jul 29, 2012 | 07:22 PM
05__g35's Avatar
I've got a check engine light that I can't seem to get to go away.
I work at Firestone and had them pull the code. I'm getting a p1078. They couldn't find any info on it through alldata, mitchell, or identifix.
I called Nissan and all they'll tell me is its not a "true" code...
I searched online and found people fixing this issue by replacing cam sensor. I replaced bank 1 rear cam sensor, reset light, and 70 miles later came back on. I switched the rear sensors hoping for a different code to appear for bank 2 code, bit 68 miles later the sad exact code appears.
I can't figure this out and don't want to have to take it to Nissan if I don't have to.
I'd appreciate any help you guys can give.
Old Jul 29, 2012 | 07:54 PM
05__g35's Avatar
Also, the car runs fine. Idles high sometimes, and feels a bit sluggish than normal
Old Jul 30, 2012 | 10:25 PM
05__g35's Avatar
Anyone?
Old Jul 31, 2012 | 12:12 AM
neo_anderson302's Avatar
If you google it will help
JUST ASK TECH - "DTC P1078 P1084 EVT CONTROL POSITION SENSORDTC P1078 P1084 EVT CONTROL POSITION SENSOR PFP:23731Component Description Exhaust valve timing control position sensor detects the concavegroove of the exhaust camshaft rear end.This sensor signal is used for sensing a position of the exhaust cam-shaft.This sensor uses a Hall IC.Based on the position of the exhaust camshaft, ECM controlsexhaust valve timing control magnet retarder to optimize the shut/open timing of exhaust valve for the driving condition.There's a problem with the cam sensor or there's a chip installed in your ECM . These need to be checked next . Most common is a faulty cam sensor . Hoped this helped. "
Old Jul 31, 2012 | 12:18 AM
05__g35's Avatar
I read that. I have googled before asking on here. All that says is the cam sensor may be bad.
Like I stated in the FIRST post. I did replace the sensor. Same side came back, swapped the sensors and then the same code came back.
There is not a chip in my ecu. The car is conpletley stock.
Old Jul 31, 2012 | 12:30 AM
Well thAt sucks u go to the dealer?
Old Nov 19, 2013 | 08:36 PM
VQSTONE's Avatar
Ever figure out what this issue was? I'm having the same issue after replacing the sensor.
Muski_G
Dec 1, 2023 11:11 AM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
