fuel gauge problem
Old Aug 22, 2012 | 11:00 PM
luky1380's Avatar
fuel gauge problem
Hi all
need some help with my 2005 G35X
few month ago gas gauge in the car started acting up, it was showing different readings every time i start the car and than will be going up or down when i drove the car, than suddenly it start working(at list that what i thought) until few days later when my wife ran out of gas (and she wasn't happy to be stuck with year old baby in the car in the middle lane at the traffic light) and gauge still was showing 1/4 of tank.
So i went do dealer got 2 (left and right) fuel sending units install them, reset ecm by disconnecting battery after that put scanner to it reset ecm through scanner, did quick adaptation of everything is possible BUT it didn't do ****, and i still have same problem it will show on gauge between 3/4-1/4 tank and I can put 18-19 gallons of fuel in it
Can it be a bad cluster or i have other problem like ecm harness connector I really dont wona take it to the dealer so any help will be appreciated
Thanks
Old Dec 2, 2013 | 02:13 PM
kenpren71's Avatar
same issue here...
did you figure out what the problems was?
Old Dec 2, 2013 | 11:09 PM
Salsa Guy's Avatar
I have a similar issue but mine will on go to little more than 1/2 way when Full. There is a TSB on it and requires sticking you arm into the gas tank. Doesn't sound like fun.
Old Dec 3, 2013 | 08:38 AM
kenpren71's Avatar
Sorry i'm new to forums what is a TSB and where can i the TSB so i can try to fix this.
thanks
ken
Old Dec 3, 2013 | 10:45 PM
Salsa Guy's Avatar
Technical Service Bulletin. There's a work around by turn the fuel nozzle upside down or something like that. Here's a link
http://infiniti.workshop-manuals.com...ex.php?id=7435
here's a G35 link
https://g35driver.com/forums/g35-sed...-gas-tank.html
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
kevintandmd
Sep 3, 2015 06:41 PM
