No crank, no start. Please help!!!
Old Dec 26, 2012 | 10:47 AM
bdubct's Avatar
just found a good fix instead of buying a new clutch pedal, use this!
https://g35driver.com/forums/engine-...al-remedy.html
Old Aug 9, 2020 | 09:06 PM
Noah Blackstock's Avatar
Infiniti G35 Sports Package
Originally Posted by bdubct
2003 g35 coupe 6 m/t 76k miles
Yesterday i went to start my car and i go to start it, nothing. No crank and it wont start. So I checked all the fuses (near clutch + under hood), all good. I tried pop starting it and it started right up and I drove home. (tested the battery 12.59 volts and the alternator at 14.8 and with a load [headlights, heat, radio] it went down to 14.4). So i ruled out it couldnt be a bad battery nor a bad alternator. no corrosion around the battery terminals. I decided to buy a new starter today, put it in and went to start the car– nothing. No crank no start still. so i pop started it again, runs like a champ. serpentine belt is good all the pulleys run strong. Not the anti-theft car alarm because it recognizes the key. So Im pretty much clueless from here.... anyone have any ideas? In the box with the new starter was a bulletin staying if you have no crank no start and have these symptoms, then you need a new IPDM (Intelligent Power Distribution Module) and for my year the part number was 284B7-AL51B.
BOTTOM LINE
-No crank no start
-not the starter, alternator, battery, fuses, car alarm
-could be the starter relay located in the IPDM, but how do i check a relay? if it was bad wouldnt it be clicking when i try to start it and the engine 'attempts' to roll over?
what else could it be?! is it the IPDM? any advice would be greatly appreciated
-thanks!
here is the bulletin i was referring to.
It definitely could be the ECU wiring harness. I would pull the kickdoor covering the ECU and see if any of the wires are loose.
Old Aug 10, 2020 | 05:45 PM
05_SkylineSedan's Avatar
20 Year Member
Not only is this an 8 year old thread but a few posts ago he solved it. In his case it was the clutch pedal switch.
Welcome to the forum though.
Old Apr 19, 2025 | 02:12 PM
slowvq95's Avatar
Originally Posted by bythabay
inspect and just the clutch pedal fully pressed switch. If all is ok there, disconnect the switch and put a wire across the two terminals of the wiring harness - this will effectively bypass the switch and allow you to start the car as if the pedal is pressed down. Make sure you are in neutral.
hi. I noticed I might have the same issue . Idk if I’m late and can get help . But I tried everything on mine and I tested the starter fuse and the fuse port for it and I get no power at all on it . So I seen the ipdm is next for the starter relay but how can I confirm before I pull the trigger for that part .
brianuc4
19
Apr 10, 2020 02:12 PM
magnetism80
Feb 1, 2019 10:00 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
sullivan72
Sep 22, 2015 11:39 PM
Rhinos7777
Sep 6, 2015 05:36 PM
