Help..2004 g35x..codes p0455 and p0430
Old Mar 7, 2013 | 07:03 PM
IDriveALex's Avatar
So my girlfriend has a 2004 g35x and its throwin codes p0455 and p0430. The car is high mileage, but I dont know what has and has not been replaced. It drives and idles fine, but her gas mileage has gone down. I know the p0430 is cat bank 2 and the p0455 points at the charcoal canister. Are the codes in any way related?
I drive a lexus gs430 and I once had a p0420 or p0430 code and it turned out to be an exhaust leak, but I also threw in two post cat sensors on it and code has not come back since.
I plan on putting it on the lift and checking for any leaks or visible damage, but can anyone tell me what is a more common fix. Would it be the cats or the sensors? I did a voltage text using a obd2 scanner and my first test looked like this
o2b1s1 0.300
o2b1s2 0.120
o2b2s1 0.590
o2b2s2 0.670
after driving it some more and coming to a stop i check it again
o2b1s1 0.300
o2b1s2 0.200
o2b2s1 0.610
o2b2s2 0.220
Just trying to get some opinions before I start throwing money in this car. thanks in advance.
Crisci33
Jun 29, 2017 08:31 AM
dookie
Jul 12, 2015 04:50 PM
worktech
21
Jun 19, 2013 11:21 AM
Str8t G
Intake & Exhaust
Jun 13, 2008 12:43 PM
2Evolved
Nov 30, 2007 10:40 PM
