Illumination/dimmer switch blowing fuses
Old Dec 15, 2013 | 05:41 PM
Speedster's Avatar
I have a 2003.5 g35 sedan that all of a sudden keeps blowing the tail light fuse as soon as I click on the headlights/parking lights. Did some looking into it and looks like it's the little dimmer switch. If I unplug it, the fuse stays ,but as soon as I plug it in , it fries the fuse. I pulled out the switch , is there a way to test if it's bad for sure and not maybe a wire leading to it grounding out? Just don't want to drop $60 for nothing. Seems like an odd part to go out randomly.
Old Dec 16, 2013 | 11:15 AM
Mustang5L5's Avatar
Do you have any aftermarket bulbs/leds that could potentially be shorted and causing the issue?
Old Dec 16, 2013 | 05:49 PM
Speedster's Avatar
No, everything is completely stock besides the jdm double din install I did 2 months ago
Old Dec 18, 2013 | 12:18 AM
Speedster's Avatar
figured out my issue. Stupid cheap *** fry's grain of wheat light bulbs that i replaced in my clock light was the problem and shorting everything out. annoying....
Dallsinghjr1
Sep 17, 2023 11:25 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
master111
Sep 25, 2015 08:32 PM
