Driver's Seat....
Old May 23, 2014 | 10:58 AM
Gradyboi78's Avatar
Driver's Seat....
I replaced the gear on the right side of the seat. Now, with the memory button pressed the lower part of the seat will not move like it did before I replaced the gear. Is there an adjustment that needs to be done?
Old May 23, 2014 | 11:38 AM
Texasscout's Avatar
Sounds like it's out of sync or something.
Old May 24, 2014 | 10:32 AM
Gradyboi78's Avatar
Do you or anyone know does the tracks have to be adjusted? Does the system have to be reset? The point of me joining this site is to get and give information. This is my second post and the first question never was answer.
Old May 24, 2014 | 11:14 AM
Texasscout's Avatar
There is a distinct possibility that nobody here knows the answer. I believe the service manual is avallable on here, try a search.
Old May 30, 2014 | 09:42 AM
chasracer's Avatar
Lets break it down first. Does that portion of the seat operate correctly using the normal adjustment button? Or is it just the memory button that is the issue here?
Old May 30, 2014 | 11:21 AM
Gradyboi78's Avatar
Just the auto-memory don't operate correctly. The steering wheel and the rest of the seat functions as should.
Old May 30, 2014 | 02:32 PM
Urbanengineer's Avatar
Did you unplug the battery when doing this? If so you have to set new places for your auto seats to go back to.
Old May 30, 2014 | 03:56 PM
Gradyboi78's Avatar
I didn't unplug the battery when I changed the gear and I did set new place for it go back to nothing. It will go back once I shut the car off and exit but will not return to the same spot after re-entering the car. Is there a way I can reset the control module under the seat?
Old May 30, 2014 | 04:11 PM
PLENUMCOUPE's Avatar
I had this exact problem with my seat saving buttons. Haven't looked into it for a while. Have u referred to the exact directions in the owners manual ?
Old May 30, 2014 | 04:20 PM
Gradyboi78's Avatar
I brought car used so I don't have an owners manual.
Old May 30, 2014 | 04:30 PM
Here it is
Attached Thumbnails Driver's Seat....-image-3271953506.jpg   Driver's Seat....-image-953953099.jpg   Driver's Seat....-image-4002216845.jpg
Old May 30, 2014 | 04:40 PM
Gradyboi78's Avatar
That is the way I have been doing it. I don't know maybe unhooking the battery may work.
Old May 30, 2014 | 06:52 PM
Originally Posted by PLENUMCOUPE
Here it is
Can the coupes have the automatic moving seat like in the sedans!?!
Old May 30, 2014 | 06:57 PM
U no what I tried setting that up but it wasn't working it may be just my seats or it only is for sedans. The directions don't say it's strictly for sedans tho.
Ludz
Lights
Mar 28, 2016 02:06 AM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
TheefrshstVQ
Jul 26, 2015 09:37 PM
