I popped a fuse and cannot find it.
Old Sep 23, 2014 | 12:54 PM
Cingular's Avatar
Currently my glovebox and ashtray lights are out and my ac display will not work and my climate control buttons are useless. I tried replacing the fuses by my foot and that did not work. Then I opened the hood and found 2 fuse boxes, I checked the fuses on both and tried replacing a few and still no luck. I ****ed up messing with the wire connected to the ash tray light, anyone have some advice on helping me find the fuse?
Old Sep 24, 2014 | 09:36 AM
05_SkylineSedan's Avatar
20 Year Member
Find your service manuals here (thanks to NICO club):
http://www.infinitiservicemanual.com
"pg.pdf" is Power and Ground.
Check:
Fusible link # C 80A (doubtful)
Fuse # 71 in your IPDM (likely)
Old Sep 24, 2014 | 03:13 PM
Cingular's Avatar
Check:
#71 was the lights problem thank you but my A/C is still not running. The control display lit up and the temperature screen did not when I initially changed the fuse but the second time and on neither are working. Im searching through those files for a fuse...
Old Sep 24, 2014 | 09:29 PM
Cingular's Avatar
So the A/C controller will light up with the lights but wont do anything along with the blank display and the seat heaters are not working or lighting up. I have read as much as I can into the manuals and researched every forum on the internet and no one seems to have ever had the same problem as me... I looked at the blower fuses, A/C fuse, Radio Fuse and other etc. fuses and still no luck. I have a 2004 g35 coupe with a Metra Dash and pioneer radio, the radio has not gone out during this whole ordeal. Living in Texas I wish it was a problem with the radio instead...
Old Sep 26, 2014 | 12:09 PM
20 Year Member
Yes, even with the manuals it takes considerable digging. Looking at your car's Power & Ground and the ATC (Automatic Air Conditioning) manuals, I see there are at least 3 fuses which could cause the AC to stop operating. Those are the10A fuses #6, #12 and #19, located in the fuse block (J/B) Picture below. Hope your issue has a simple fix!
Old Sep 27, 2014 | 02:41 AM
westsideblu's Avatar
I had the same problem and at first I couldnt find the fuse because its hard to see unless you stick your head all the way by the pedals its the 10a in the far left bottom corner the #12 spot that was my problem. If that doesnt work nicoclub forums have all the fsm's download ill try post the link.
Old Sep 27, 2014 | 02:44 AM
http://forums.nicoclub.com/fsm-list-for-your-g-t525067.html
this is the url to the list of car models. Just selected your car and itll take you to a list of all the fsm's atc is the one youll need.
Old Sep 27, 2014 | 01:44 PM
Cingular's Avatar
It ended up being a fuse I just checked by eye and was blown but didn't look blown.
Old Sep 28, 2014 | 12:47 AM
bluedevils95's Avatar
So you going to buy a new one now? At lease an auto store will have that fuse you'll be looking for.
2014g35x
Jul 30, 2015 09:32 AM
.cakestar
Jul 28, 2015 01:57 PM
newg37
Jul 26, 2015 09:32 AM
Cskeet
Jul 21, 2015 05:48 PM
