Electrical issue.. no backlight in cluster, no A/C or radio
Old Dec 20, 2014 | 08:00 PM
Rojas's Avatar
Angry Electrical issue.. no backlight in cluster, no A/C or radio
New member here. I tried posting this same problem on a different forum site with no luck.
I've tried searching for this problem and every post I find the OP usually never went back to resolve, or someone else's fix I've already tried.
I dropped my car off at my local mechanic shop just to have my belts replaced, AC and power steering I think they were, and because my car was overheating. I needed a new thermostat and my radiator ended up having a small leak I never noticed. Anyway, two days later ( Driving just fine ) after work I go outside to start her up and run into these symptoms.
1. No lighting in my cluster ( speedo, gas, rpm, eng. temp, and some emergency lights still work)
2. ABS light turns on once the brake is pressed.
3. No rear brake lights
4. Gear will not go into D (Will not go out of park without using shift lock)
5. No AC/HEAT or radio
6. No power seats
All I can remember at the moment...
Surprisingly, some stuff still works such as..
1. The car starts up just fine
2. Dome lights in the cabin
3. Headlights, Blinkers, fogs ..
4. Power windows
5. Wipers
UPDATE.
No fuses blown in any of the 3 fuse boxes. I tried replacing the mirror fuse in the kick panel box because I read on another post it was what controlled all accessories in the cabin. Brake light switch has been replaced. Brake fluid is over the half way point a little from MAX.
If it means anything, the night before I clipped my right side mirror.
Any ideas? Thank you
Driving a 03 G35 with around 130k
Old Dec 21, 2014 | 11:33 AM
05_SkylineSedan's Avatar
20 Year Member
What a drag! Check your "fusible links" which are like the "master" fuses and are built in to the positive battery connector cable. Brake lights should be the easiest to trace since they should always be powered and only run through two fuses. (See below). Fusible link D is a 60 amp fuse that runs a whole bunch of things. Hopefully that's the problem. Fuse 20 is in the in-cabin fuse box.
Attached Thumbnails Electrical issue.. no backlight in cluster, no A/C or radio-stoplamp.jpg
Old Dec 22, 2014 | 07:16 PM
Rojas's Avatar
Thank you for your help. Sadly, Fuse 20 is functional. The fusible link from what i see is not broken or cracked. Is there a trick to telling wether or not the fusible link is operational? even though the metal connects could it be bad? or is it just visual, if the metal connects its fine I assume? If that's the case the fusible link is operational. This leads me to believe the issue is with the wiring somewhere? I'm not good with this stuff but is there a way I can look up a diagram of where the wiring runs from the fuse box to the brake lights? Maybe if i follow it I will find my problem, and all the others as well.
Old Dec 22, 2014 | 07:55 PM
Justice06RR's Avatar
How long have you owned this car, and is there any accident history? I'm only asking because once the car is in a major accident, many of these functions are affected although they are replaced/fixed.
I cannot say as I'm new to Infiniti's, other than try to take it to the Infiniti dealer as they will know how to diagnose it. it'll cost at least $150 for a full diagnostic; thats how much I paid for mine a couple of months ago. Good luck!
Old Dec 23, 2014 | 10:51 PM
Rojas's Avatar
I never checked but I've owned the car for 6 months. I'll check the history.
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Learned Hand
Oct 1, 2015 09:02 AM
wow600rr
Sep 28, 2015 11:50 AM
Jcruzg35
Sep 26, 2015 04:47 PM
